HP Media Center 876x Optical Drive Replacement
    1. HP Media Center 876x Optical Drive Replacement, Side Panel: step 1, image 1 of 2 HP Media Center 876x Optical Drive Replacement, Side Panel: step 1, image 2 of 2
      • Remove the two (9 mm) hand screws on the back panel.
      Ask FixBot
    2. HP Media Center 876x Optical Drive Replacement: step 2, image 1 of 3 HP Media Center 876x Optical Drive Replacement: step 2, image 2 of 3 HP Media Center 876x Optical Drive Replacement: step 2, image 3 of 3
      • Place the tower on its side.
      • Slide the side panel horizontally to detach, and pull upward to remove.
      Ask FixBot
    1. HP Media Center 876x Optical Drive Replacement, Front Cover: step 3, image 1 of 2 HP Media Center 876x Optical Drive Replacement, Front Cover: step 3, image 2 of 2
      • Orient the tower vertically.
      • Using the #0 Phillips head screwdriver, unscrew and remove the two (5 mm) screws that fasten the remaining side panel to the tower.
      • Slide the side panel out of its notches, and pull it gently off of the tower.
      Ask FixBot
    2. HP Media Center 876x Optical Drive Replacement: step 4, image 1 of 1
      • Gently move the tower so that it is in the horizontal orientation.
      • Press down the black tabs (proximal to you) that fasten the front panel to the tower.
      • Press down on the distal, black tabs (symmetric with respect to the previous tabs).
      • Pull front panel forward slightly.
      Ask FixBot
    3. HP Media Center 876x Optical Drive Replacement: step 5, image 1 of 2 HP Media Center 876x Optical Drive Replacement: step 5, image 2 of 2
      • The front panel will come off in a hinge-like fashion, exposing the drives underneath.
      Ask FixBot
    1. HP Media Center 876x Optical Drive Replacement, Optical Drive: step 6, image 1 of 3 HP Media Center 876x Optical Drive Replacement, Optical Drive: step 6, image 2 of 3 HP Media Center 876x Optical Drive Replacement, Optical Drive: step 6, image 3 of 3
      • Identify the optical drive.
      • Pull the molex connectors out of the posterior end of the optical drive.
      Ask FixBot
    2. HP Media Center 876x Optical Drive Replacement: step 7, image 1 of 3 HP Media Center 876x Optical Drive Replacement: step 7, image 2 of 3 HP Media Center 876x Optical Drive Replacement: step 7, image 3 of 3
      • Pull the ribbon cable out of the back of the optical drive.
      Ask FixBot
    3. HP Media Center 876x Optical Drive Replacement: step 8, image 1 of 3 HP Media Center 876x Optical Drive Replacement: step 8, image 2 of 3 HP Media Center 876x Optical Drive Replacement: step 8, image 3 of 3
      • Using the Phillips #0 screwdriver, remove the two 5 mm screws that fasten the optical drive into its port.
      • Gently pull the optical drive through the front cavity.
      Ask FixBot
    4. HP Media Center 876x Optical Drive Replacement: step 9, image 1 of 2 HP Media Center 876x Optical Drive Replacement: step 9, image 2 of 2
      • Remove the optical drive completely from its port.
      Ask FixBot
2 other people completed this guide.
Balakrishnan Pillai
1,003 Reputation
8 Guides authored
Clemson, Team 6-1, Benson Spring 2014 Member of Clemson, Team 6-1, Benson Spring 2014
CLEM-BENSON-S14S6G1
3 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 32
Past 30 Days: 47
All Time: 826
