HP Media Center 876x Front Cover Replacement
  1. HP Media Center 876x Front Cover Replacement, Side Panel: step 1, image 1 of 2 HP Media Center 876x Front Cover Replacement, Side Panel: step 1, image 2 of 2
    • Remove the two (9 mm) hand screws on the back panel.
    Ask FixBot
  2. HP Media Center 876x Front Cover Replacement: step 2, image 1 of 3 HP Media Center 876x Front Cover Replacement: step 2, image 2 of 3 HP Media Center 876x Front Cover Replacement: step 2, image 3 of 3
    • Place the tower on its side.
    • Slide the side panel horizontally to detach, and pull upward to remove.
    Ask FixBot
  3. HP Media Center 876x Front Cover Replacement, Front Cover: step 3, image 1 of 2 HP Media Center 876x Front Cover Replacement, Front Cover: step 3, image 2 of 2
    • Orient the tower vertically.
    • Using the #0 Phillips head screwdriver, unscrew and remove the two (5 mm) screws that fasten the remaining side panel to the tower.
    • Slide the side panel out of its notches, and pull it gently off of the tower.
    Ask FixBot
  4. HP Media Center 876x Front Cover Replacement: step 4, image 1 of 1
    • Gently move the tower so that it is in the horizontal orientation.
    • Press down the black tabs (proximal to you) that fasten the front panel to the tower.
    • Press down on the distal, black tabs (symmetric with respect to the previous tabs).
    • Pull front panel forward slightly.
    Ask FixBot
  5. HP Media Center 876x Front Cover Replacement: step 5, image 1 of 2 HP Media Center 876x Front Cover Replacement: step 5, image 2 of 2
    • The front panel will come off in a hinge-like fashion, exposing the drives underneath.
    Ask FixBot
Balakrishnan Pillai
1,003 Reputation
8 Guides authored
Clemson, Team 6-1, Benson Spring 2014 Member of Clemson, Team 6-1, Benson Spring 2014
CLEM-BENSON-S14S6G1
3 Members
15 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 41
All Time: 883
