HP LaserJet P1102w Motherboard Replacement
  1. HP LaserJet P1102w Motherboard Replacement, Left Side Panel: step 1, image 1 of 3 HP LaserJet P1102w Motherboard Replacement, Left Side Panel: step 1, image 2 of 3 HP LaserJet P1102w Motherboard Replacement, Left Side Panel: step 1, image 3 of 3
    • Flip printer on it's back. Using the plastic spudger, pry off front panel. There will be two main points to focus as shown.
    • Pry carefully to not break any plastic.
    Ask FixBot
  2. HP LaserJet P1102w Motherboard Replacement: step 2, image 1 of 2 HP LaserJet P1102w Motherboard Replacement: step 2, image 2 of 2
    • Now that the pry points are free lift up the front panel.
    Ask FixBot
  3. HP LaserJet P1102w Motherboard Replacement: step 3, image 1 of 2 HP LaserJet P1102w Motherboard Replacement: step 3, image 2 of 2
    • Unscrew the #1 Phillips screw 6mm on the back of the printer.
    Ask FixBot
  4. HP LaserJet P1102w Motherboard Replacement: step 4, image 1 of 3 HP LaserJet P1102w Motherboard Replacement: step 4, image 2 of 3 HP LaserJet P1102w Motherboard Replacement: step 4, image 3 of 3
    • Using the plastic spudger, remove the button housing from the top left of printer.
    Ask FixBot
  5. HP LaserJet P1102w Motherboard Replacement: step 5, image 1 of 2 HP LaserJet P1102w Motherboard Replacement: step 5, image 2 of 2
    • Once the housing is removed, remove the three buttons.
    Ask FixBot
  6. HP LaserJet P1102w Motherboard Replacement: step 6, image 1 of 3 HP LaserJet P1102w Motherboard Replacement: step 6, image 2 of 3 HP LaserJet P1102w Motherboard Replacement: step 6, image 3 of 3
    • Use the plastic spudger to remove the side panel. There are three main prying points as shown.
    Ask FixBot
  7. HP LaserJet P1102w Motherboard Replacement: step 7, image 1 of 2 HP LaserJet P1102w Motherboard Replacement: step 7, image 2 of 2
    • With all pry points free, remove the side panel.
    Ask FixBot
  8. HP LaserJet P1102w Motherboard Replacement, Motherboard: step 8, image 1 of 3 HP LaserJet P1102w Motherboard Replacement, Motherboard: step 8, image 2 of 3 HP LaserJet P1102w Motherboard Replacement, Motherboard: step 8, image 3 of 3
    • Remove three #1 Phillips 6mm screws with the #1 Phillips screwdriver.
    Ask FixBot
  9. HP LaserJet P1102w Motherboard Replacement: step 9, image 1 of 3 HP LaserJet P1102w Motherboard Replacement: step 9, image 2 of 3 HP LaserJet P1102w Motherboard Replacement: step 9, image 3 of 3
    Tool used on this step:
    Buy
    • Using a pair of blunt nose tweezers, disconnect both ribbon wires.
    • With both ribbon wires removed we can lift the motherboard out of its housing.
    • There is a little black notch holding the motherboard down by the thumb in the final picture.
    • Be careful pulling, as ribbon wires are very fragile.
    Ask FixBot
5 other people completed this guide.
Jerome Etten
784 Reputation
4 Guides authored
UW Stout, Team S6-G4, Ogden Fall 2018 Member of UW Stout, Team S6-G4, Ogden Fall 2018
UWSTOUT-OGDEN-F18S6G4
4 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 83
All Time: 2,973
