HP LaserJet P1102w Left Side Panel Replacement
    1. HP LaserJet P1102w Left Side Panel Replacement, Left Side Panel: step 1, image 1 of 3 HP LaserJet P1102w Left Side Panel Replacement, Left Side Panel: step 1, image 2 of 3 HP LaserJet P1102w Left Side Panel Replacement, Left Side Panel: step 1, image 3 of 3
      • Flip printer on it's back. Using the plastic spudger, pry off front panel. There will be two main points to focus as shown.
      • Pry carefully to not break any plastic.
      Ask FixBot
    2. HP LaserJet P1102w Left Side Panel Replacement: step 2, image 1 of 2 HP LaserJet P1102w Left Side Panel Replacement: step 2, image 2 of 2
      • Now that the pry points are free lift up the front panel.
      Ask FixBot
    3. HP LaserJet P1102w Left Side Panel Replacement: step 3, image 1 of 2 HP LaserJet P1102w Left Side Panel Replacement: step 3, image 2 of 2
      • Unscrew the #1 Phillips screw 6mm on the back of the printer.
      Ask FixBot
    4. HP LaserJet P1102w Left Side Panel Replacement: step 4, image 1 of 3 HP LaserJet P1102w Left Side Panel Replacement: step 4, image 2 of 3 HP LaserJet P1102w Left Side Panel Replacement: step 4, image 3 of 3
      • Using the plastic spudger, remove the button housing from the top left of printer.
      Ask FixBot
    5. HP LaserJet P1102w Left Side Panel Replacement: step 5, image 1 of 2 HP LaserJet P1102w Left Side Panel Replacement: step 5, image 2 of 2
      • Once the housing is removed, remove the three buttons.
      Ask FixBot
    6. HP LaserJet P1102w Left Side Panel Replacement: step 6, image 1 of 3 HP LaserJet P1102w Left Side Panel Replacement: step 6, image 2 of 3 HP LaserJet P1102w Left Side Panel Replacement: step 6, image 3 of 3
      • Use the plastic spudger to remove the side panel. There are three main prying points as shown.
      Ask FixBot
    7. HP LaserJet P1102w Left Side Panel Replacement: step 7, image 1 of 2 HP LaserJet P1102w Left Side Panel Replacement: step 7, image 2 of 2
      • With all pry points free, remove the side panel.
      Ask FixBot
3 other people completed this guide.
Jerome Etten
805 Reputation
4 Guides authored
UW Stout, Team S6-G4, Ogden Fall 2018 Member of UW Stout, Team S6-G4, Ogden Fall 2018
UWSTOUT-OGDEN-F18S6G4
4 Members
60 Guides authored
1 Guide Comment
How to replace the HP 2055 motherboard
Wale - Reply Share
Past 24 Hours: 2
Past 7 Days: 21
Past 30 Days: 87
All Time: 2,997
