HP LaserJet P1102w Drive Belt Replacement
  1. HP LaserJet P1102w Drive Belt Replacement, Left Side Panel: step 1, image 1 of 3 HP LaserJet P1102w Drive Belt Replacement, Left Side Panel: step 1, image 2 of 3 HP LaserJet P1102w Drive Belt Replacement, Left Side Panel: step 1, image 3 of 3
    • Flip printer on it's back. Using the plastic spudger, pry off front panel. There will be two main points to focus as shown.
    • Pry carefully to not break any plastic.
    Ask FixBot
  2. HP LaserJet P1102w Drive Belt Replacement: step 2, image 1 of 2 HP LaserJet P1102w Drive Belt Replacement: step 2, image 2 of 2
    • Now that the pry points are free lift up the front panel.
    Ask FixBot
  3. HP LaserJet P1102w Drive Belt Replacement: step 3, image 1 of 2 HP LaserJet P1102w Drive Belt Replacement: step 3, image 2 of 2
    • Unscrew the #1 Phillips screw 6mm on the back of the printer.
    Ask FixBot
  4. HP LaserJet P1102w Drive Belt Replacement: step 4, image 1 of 3 HP LaserJet P1102w Drive Belt Replacement: step 4, image 2 of 3 HP LaserJet P1102w Drive Belt Replacement: step 4, image 3 of 3
    • Using the plastic spudger, remove the button housing from the top left of printer.
    Ask FixBot
  5. HP LaserJet P1102w Drive Belt Replacement: step 5, image 1 of 2 HP LaserJet P1102w Drive Belt Replacement: step 5, image 2 of 2
    • Once the housing is removed, remove the three buttons.
    Ask FixBot
  6. HP LaserJet P1102w Drive Belt Replacement: step 6, image 1 of 3 HP LaserJet P1102w Drive Belt Replacement: step 6, image 2 of 3 HP LaserJet P1102w Drive Belt Replacement: step 6, image 3 of 3
    • Use the plastic spudger to remove the side panel. There are three main prying points as shown.
    Ask FixBot
  7. HP LaserJet P1102w Drive Belt Replacement: step 7, image 1 of 2 HP LaserJet P1102w Drive Belt Replacement: step 7, image 2 of 2
    • With all pry points free, remove the side panel.
    Ask FixBot
  8. HP LaserJet P1102w Drive Belt Replacement, Drive Belt: step 8, image 1 of 3 HP LaserJet P1102w Drive Belt Replacement, Drive Belt: step 8, image 2 of 3 HP LaserJet P1102w Drive Belt Replacement, Drive Belt: step 8, image 3 of 3
    • Refer to the prerequisite guide to take off the front panel off.
    • With a #1 Phillips screwdriver remove only the top Phillips 60mm screw.
    • With the spudger pry the side panel off. There will be four flanges to unhitch.
    Ask FixBot
  9. HP LaserJet P1102w Drive Belt Replacement: step 9, image 1 of 2 HP LaserJet P1102w Drive Belt Replacement: step 9, image 2 of 2
    • With side panel removed, there will be four Phillips 60mm screws to unscrew using a #1 Phillips screwdriver.
    Ask FixBot
  10. HP LaserJet P1102w Drive Belt Replacement: step 10, image 1 of 3 HP LaserJet P1102w Drive Belt Replacement: step 10, image 2 of 3 HP LaserJet P1102w Drive Belt Replacement: step 10, image 3 of 3
    Tool used on this step:
    Buy
    • Remove top two big gears using tweezers.
    • Take note of gear placement.
    Ask FixBot
  11. HP LaserJet P1102w Drive Belt Replacement: step 11, image 1 of 3 HP LaserJet P1102w Drive Belt Replacement: step 11, image 2 of 3 HP LaserJet P1102w Drive Belt Replacement: step 11, image 3 of 3
    • With the #1 Phillips screwdriver remove the 60mm Phillips screw holding the belt tension-er.
    • With the screw removed, pull tension-er out.
    • Use tweezers to remove the loose drive belt.
    Ask FixBot
6 other people completed this guide.
Jerome Etten
784 Reputation
4 Guides authored
UW Stout, Team S6-G4, Ogden Fall 2018 Member of UW Stout, Team S6-G4, Ogden Fall 2018
UWSTOUT-OGDEN-F18S6G4
4 Members
12 Guides authored
3 Guide Comments
the tight side panel clips make this a difficult procedure, so take care both disassembling and assembling, for example make sure the power button is aligned with the level components behind before you push to clip the front home, as misalignment can break or dislocate internal parts.
Peter Taffs - Reply Share
Que dois je faire si mon imprimante fait beaucoup de bruit en imprimant et que la totalité de feuille imprimée ne sort pas?
anelka VILPIGUE - Reply Share
In my case, the roller is worn out. I haven't been able to find a replacement. Can you give me the part code so I can buy it?
EleCom - Reply Share
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 101
All Time: 4,645
