HP LaserJet 1160 or 1320 Control Panel Replacement
Views: 1.3K
View statistics:
Past 24 Hours:
3
Past 7 Days:
17
Past 30 Days:
87
All Time:
1,301
Comments: 2
2 comments on steps.
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 minutes
Difficulty: Easy
Community-Contributed Guide
Parts
Tools
    1. HP LaserJet 1160 or 1320 Control Panel Replacement, Left Side Cover: step 1, image 1 of 3 HP LaserJet 1160 or 1320 Control Panel Replacement, Left Side Cover: step 1, image 2 of 3 HP LaserJet 1160 or 1320 Control Panel Replacement, Left Side Cover: step 1, image 3 of 3
      • Pull on the two tabs on the back of the printer to release the left side cover.
      • Remove the cover by rotating it towards the front of the printer.
      Ask FixBot
    1. HP LaserJet 1160 or 1320 Control Panel Replacement, Right Side Cover: step 2, image 1 of 3 HP LaserJet 1160 or 1320 Control Panel Replacement, Right Side Cover: step 2, image 2 of 3 HP LaserJet 1160 or 1320 Control Panel Replacement, Right Side Cover: step 2, image 3 of 3
      • With the printer turned so that the right side is facing upwards, use a metal spudger to disengage 3 tabs holding the right side cover in place.
      • Lift the cover off of the printer.
      Ask FixBot
    1. HP LaserJet 1160 or 1320 Control Panel Replacement, Back Cover: step 3, image 1 of 3 HP LaserJet 1160 or 1320 Control Panel Replacement, Back Cover: step 3, image 2 of 3 HP LaserJet 1160 or 1320 Control Panel Replacement, Back Cover: step 3, image 3 of 3
      • Remove 4 screws on the back of the printer.
      • Remove the back cover.
      Ask FixBot
    1. HP LaserJet 1160 or 1320 Control Panel Replacement, Top Cover: step 4, image 1 of 3 HP LaserJet 1160 or 1320 Control Panel Replacement, Top Cover: step 4, image 2 of 3 HP LaserJet 1160 or 1320 Control Panel Replacement, Top Cover: step 4, image 3 of 3
      • Remove 2 screws on the back of the printer, one on the left, and one on the front.
      • The second image shows the formatter removed, but it is not necessary to remove the formatter to replace the top cover.
      Ask FixBot
    2. HP LaserJet 1160 or 1320 Control Panel Replacement, Top Cover: step 5, image 1 of 1
      • Disconnect the control panel cable and remove the top cover.
      Ask FixBot
    1. HP LaserJet 1160 or 1320 Control Panel Replacement, Control Panel: step 6, image 1 of 3 HP LaserJet 1160 or 1320 Control Panel Replacement, Control Panel: step 6, image 2 of 3 HP LaserJet 1160 or 1320 Control Panel Replacement, Control Panel: step 6, image 3 of 3
      • Use a metal spudger to remove the control panel and its circuit board from the top cover.
      Ask FixBot
jdp23
1,312 Reputation
23 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 87
All Time: 1,301
