HP HDX 16-1160US Wifi Card Replacement
    1. HP HDX 16-1160US Wifi Card Replacement, Battery: step 1, image 1 of 1
      • Turn the device over so that the bottom side is facing up and the battery is facing away from you.
      Ask FixBot
    2. HP HDX 16-1160US Wifi Card Replacement: step 2, image 1 of 3 HP HDX 16-1160US Wifi Card Replacement: step 2, image 2 of 3 HP HDX 16-1160US Wifi Card Replacement: step 2, image 3 of 3
      • Locate the slider under the right side of the battery.
      • Using your thumb, slide it all the way to the left until the front of the battery lifts up.
      Ask FixBot
    3. HP HDX 16-1160US Wifi Card Replacement: step 3, image 1 of 1
      • With your thumb still holding the slider to the left, use the opposite hand to lift the battery out, removing it from the computer.
      Ask FixBot
    1. HP HDX 16-1160US Wifi Card Replacement, Wifi Card: step 4, image 1 of 2 HP HDX 16-1160US Wifi Card Replacement, Wifi Card: step 4, image 2 of 2
      • Use the Phillips #1 Screw Driver to unscrew the 6mm screw from the Wi-Fi Card Panel.
      • The 6mm screw will remain in the Wi-Fi card panel and will not fall out.
      • Lift off the Wi-Fi card panel off using the opposite hand.
      Ask FixBot
    2. HP HDX 16-1160US Wifi Card Replacement: step 5, image 1 of 2 HP HDX 16-1160US Wifi Card Replacement: step 5, image 2 of 2
      • Remove the gray and black wires by gently pulling up on them so that they "unsnap" from the Wi-Fi card.
      Ask FixBot
    3. HP HDX 16-1160US Wifi Card Replacement: step 6, image 1 of 1
      • Remove the two 4mm screws with the Phillips #1 screw driver.
      Ask FixBot
    4. HP HDX 16-1160US Wifi Card Replacement: step 7, image 1 of 1
      • Carefully use the plastic opening tools to lift the Wi-Fi card up on the left side.
      • Using the opposite hand, pull the Wi-Fi card to the left.
      • Do not lift the Wi-Fi card straight up, this will damage or break the Wi-Fi card.
      Ask FixBot
2 other people completed this guide.
Marshall Reid
527 Reputation
3 Guides authored
Cal Poly, Team 12-38, Maness Spring 2014 Member of Cal Poly, Team 12-38, Maness Spring 2014
CPSU-MANESS-S14S12G38
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 27
All Time: 1,466
