HP HDX 16-1160US RAM Replacement
    1. HP HDX 16-1160US RAM Replacement, RAM: step 1, image 1 of 2 HP HDX 16-1160US RAM Replacement, RAM: step 1, image 2 of 2
      • Flip the device over so that the bottom side is facing up and use the Phillips #1 Screw Driver to remove the four 4mm screws on the cover panel.
      • Lift the panel to remove it from the device.
      Ask FixBot
    2. HP HDX 16-1160US RAM Replacement: step 2, image 1 of 3 HP HDX 16-1160US RAM Replacement: step 2, image 2 of 3 HP HDX 16-1160US RAM Replacement: step 2, image 3 of 3
      • Remove the RAM by placing your thumbs on the silver tabs on each side of the RAM stick and pulling the tabs away from the RAM stick.
      • The RAM stick should "flip" up when it is released from its holders.
      • Pull the RAM stick toward you to remove it.
      • Repeat the above step to remove the second RAM stick
      Ask FixBot
2 other people completed this guide.
Marshall Reid
527 Reputation
3 Guides authored
Cal Poly, Team 12-38, Maness Spring 2014 Member of Cal Poly, Team 12-38, Maness Spring 2014
CPSU-MANESS-S14S12G38
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 25
Past 30 Days: 99
All Time: 1,092
