HP HDX 16-1160US Battery Replacement
Views: 1.2K
View statistics:
Past 24 Hours:
2
Past 7 Days:
21
Past 30 Days:
88
All Time:
1,186
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 20 seconds
Difficulty: Very easy
Introduction
Go to step 1 ↓
A guide to replace the battery on the HP HDX 16-1160US.
    1. HP HDX 16-1160US Battery Replacement, Battery: step 1, image 1 of 1
      • Turn the device over so that the bottom side is facing up and the battery is facing away from you.
      Ask FixBot
    2. HP HDX 16-1160US Battery Replacement: step 2, image 1 of 3 HP HDX 16-1160US Battery Replacement: step 2, image 2 of 3 HP HDX 16-1160US Battery Replacement: step 2, image 3 of 3
      • Locate the slider under the right side of the battery.
      • Using your thumb, slide it all the way to the left until the front of the battery lifts up.
      Ask FixBot
    3. HP HDX 16-1160US Battery Replacement: step 3, image 1 of 1
      • With your thumb still holding the slider to the left, use the opposite hand to lift the battery out, removing it from the computer.
      Ask FixBot
2 other people completed this guide.
Daniel McBroom
278 Reputation
2 Guides authored
Cal Poly, Team 12-38, Maness Spring 2014 Member of Cal Poly, Team 12-38, Maness Spring 2014
CPSU-MANESS-S14S12G38
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 21
Past 30 Days: 88
All Time: 1,186
