Up to 20% off select tools
HP G72 WLAN module Replacement
Views: 1.8K
View statistics:
Past 24 Hours:
5
Past 7 Days:
18
Past 30 Days:
82
All Time:
1,750
Comments: 0
Go to guide comments
Completed: 0
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 10 minutes
Difficulty: Easy
Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓
To work on this laptop, or any other device, it is important to shut down the computer. If you are unsure whether the computer is off or in Hibernation, turn on the computer, and then shut it down through the operating system. Disconnect all external devices connected to the computer. Disconnect the power from the computer by first disconnecting the power cord from the AC outlet and then disconnecting the AC adapter from the computer. Memory module had failed and needed to be replaced.
    1. HP G72 WLAN module Replacement, WLAN module: step 1, image 1 of 3 HP G72 WLAN module Replacement, WLAN module: step 1, image 2 of 3 HP G72 WLAN module Replacement, WLAN module: step 1, image 3 of 3
      • Shut down the computer. Disconnect all external devices connected to the computer. Disconnect the power from the computer by first disconnecting the power cord from the AC outlet and then disconnecting the AC adapter from the computer.
      • Turn the computer so that it faces upside down. Position the computer with the front toward you.
      • Slide the battery release latch to release the battery. Pivot the battery to remove it.
      Ask FixBot
    2. HP G72 WLAN module Replacement: step 2, image 1 of 3 HP G72 WLAN module Replacement: step 2, image 2 of 3 HP G72 WLAN module Replacement: step 2, image 3 of 3
      • Loosen the three Phillips M2.5×6.0 captive screws that secure the memory module compartment cover.
      • Use a plastic opening tool (or equivalent) to lift the back side of the cover. Small tabs hold the cover in place. Firmly pull up on the cover to release the tabs.
      • Remove the cover
      Ask FixBot
    3. HP G72 WLAN module Replacement: step 3, image 1 of 3 HP G72 WLAN module Replacement: step 3, image 2 of 3 HP G72 WLAN module Replacement: step 3, image 3 of 3
      • Disconnect the main antenna cable
      • Disconnect the auxiliary antenna cable
      • Remove the Phillips M2.0×3.0 screw that secures the WLAN module to the computer.
      Ask FixBot
    4. HP G72 WLAN module Replacement: step 4, image 1 of 1
      • Remove the WLAN module by pulling it away from the slot at an angle.
      Ask FixBot
Author
with
oldturkey03
867,030 Reputation
123 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 18
Past 30 Days: 82
All Time: 1,750
