HP G71t-400 Cooling Fan Replacement
    1. HP G71t-400 Cooling Fan Replacement, Cooling Fan: step 1, image 1 of 3 HP G71t-400 Cooling Fan Replacement, Cooling Fan: step 1, image 2 of 3 HP G71t-400 Cooling Fan Replacement, Cooling Fan: step 1, image 3 of 3
      • Lay the laptop down so the bottom is facing up.
      • Push the slide button, circled in photo 1, to release the battery.
      • Action in picture 2 shows the direction and release.
      • Tilt the battery back in the direction it popped up in and remove the battery.
      • This ensures there is no power in the system that could potentially short out any components.
      Ask FixBot
    2. HP G71t-400 Cooling Fan Replacement: step 2, image 1 of 3 HP G71t-400 Cooling Fan Replacement: step 2, image 2 of 3 HP G71t-400 Cooling Fan Replacement: step 2, image 3 of 3
      • Remove the circled screws.
      • Remove the cover, exposing the hard drive and RAM.
      Ask FixBot
    3. HP G71t-400 Cooling Fan Replacement: step 3, image 1 of 3 HP G71t-400 Cooling Fan Replacement: step 3, image 2 of 3 HP G71t-400 Cooling Fan Replacement: step 3, image 3 of 3
      • Remove the 2 circled screws.
      • Use your pry to slide the hard drive over. This unplugs it from its connection and allows it to be removed.
      • Remove the hard drive.
      Ask FixBot
    4. HP G71t-400 Cooling Fan Replacement: step 4, image 1 of 2 HP G71t-400 Cooling Fan Replacement: step 4, image 2 of 2
      • Push the silver tabs in to release the RAM.
      • When they pop up from the locked position they may be removed.
      • Remove the circled screws to release the WiFi card and keyboard.
      Ask FixBot
    5. HP G71t-400 Cooling Fan Replacement: step 5, image 1 of 3 HP G71t-400 Cooling Fan Replacement: step 5, image 2 of 3 HP G71t-400 Cooling Fan Replacement: step 5, image 3 of 3
      • Remove the panel, exposing the WiFi card.
      • Remove the circle wire connections, make note to which port they were connected to.
      • Remove the WiFi card.
      Ask FixBot
    6. HP G71t-400 Cooling Fan Replacement: step 6, image 1 of 3 HP G71t-400 Cooling Fan Replacement: step 6, image 2 of 3 HP G71t-400 Cooling Fan Replacement: step 6, image 3 of 3
      • Flip the laptop over and open it now that the keyboard has been unscrewed.
      • Take your pry bar and go around the outer edge of the keyboard. Popping it free from the bezel.
      Ask FixBot
    7. HP G71t-400 Cooling Fan Replacement: step 7, image 1 of 3 HP G71t-400 Cooling Fan Replacement: step 7, image 2 of 3 HP G71t-400 Cooling Fan Replacement: step 7, image 3 of 3
      • Lift the keyboard up.
      • Remove the connections from the keyboard to the motherboard.
      • Remember each attachments position because they will need to be connected again.
      Ask FixBot
    8. HP G71t-400 Cooling Fan Replacement: step 8, image 1 of 3 HP G71t-400 Cooling Fan Replacement: step 8, image 2 of 3 HP G71t-400 Cooling Fan Replacement: step 8, image 3 of 3
      • Remove the circled screws to release the bezel from the faceplate.
      Ask FixBot
    9. HP G71t-400 Cooling Fan Replacement: step 9, image 1 of 2 HP G71t-400 Cooling Fan Replacement: step 9, image 2 of 2
      • Lift the bezel from the face plate.
      • Disconnect the power connection from the bezel to the motherboard.
      Ask FixBot
    10. HP G71t-400 Cooling Fan Replacement: step 10, image 1 of 3 HP G71t-400 Cooling Fan Replacement: step 10, image 2 of 3 HP G71t-400 Cooling Fan Replacement: step 10, image 3 of 3
      • Remove the two screws side-by-side next to each in the red circle.
      • This will be the last layer to remove before reaching the motherboard.
      Ask FixBot
    11. HP G71t-400 Cooling Fan Replacement: step 11, image 1 of 2 HP G71t-400 Cooling Fan Replacement: step 11, image 2 of 2
      • Carefully detach the highlighted connections.
      • Remove the motherboard from the device.
      Ask FixBot
    12. HP G71t-400 Cooling Fan Replacement: step 12, image 1 of 3 HP G71t-400 Cooling Fan Replacement: step 12, image 2 of 3 HP G71t-400 Cooling Fan Replacement: step 12, image 3 of 3
      • Remove three screws to detach the cooling fan from the motherboard.
      • Remove the last connection.
      Ask FixBot
Nicholas Castro
720 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 21
All Time: 444
