HP G71t-300 Wi-Fi Card Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
26
Past 30 Days:
97
All Time:
539
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 - 15 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
If you choose to replace the module with different specifications, download the driver for the new module before replacing the wifi module.
Tools
    1. HP G71t-300 Wi-Fi Card Replacement, Wi-Fi Card: step 1, image 1 of 3 HP G71t-300 Wi-Fi Card Replacement, Wi-Fi Card: step 1, image 2 of 3 HP G71t-300 Wi-Fi Card Replacement, Wi-Fi Card: step 1, image 3 of 3
      Tool used on this step:
      Anti-Static Wrist Strap
      $7.95
      Buy
      • Ground yourself by either touching an unpainted metal surface or by using the Anti-Static wrist strap.
      • Turn off the computer and remove the charger from the charging port.
      • Turn the laptop over and slide the battery release catch to the right. The battery will pop up from its slot. Remove the battery using your fingers.
      Ask FixBot
    2. HP G71t-300 Wi-Fi Card Replacement: step 2, image 1 of 1
      • Remove the 6mm screw from the cover above the battery using a Phillips #0 screwdriver.
      Ask FixBot
    3. HP G71t-300 Wi-Fi Card Replacement: step 3, image 1 of 1
      • Pull off the bottom cover to reveal the Wi-Fi card.
      Ask FixBot
    4. HP G71t-300 Wi-Fi Card Replacement: step 4, image 1 of 3 HP G71t-300 Wi-Fi Card Replacement: step 4, image 2 of 3 HP G71t-300 Wi-Fi Card Replacement: step 4, image 3 of 3
      • Gently remove the 2 cables clips to avoid damage.
      • Remove the 3mm screw holding the Wi-Fi module using a Phillips #0 screwdriver.
      Ask FixBot
    5. HP G71t-300 Wi-Fi Card Replacement: step 5, image 1 of 2 HP G71t-300 Wi-Fi Card Replacement: step 5, image 2 of 2
      • Gently pull the module out of the slot.
      Ask FixBot
Cecil Lam
113 Reputation
1 Guide authored
UC Davis, Team 2-3, Oliver Fall 2016 Member of UC Davis, Team 2-3, Oliver Fall 2016
UCD-OLIVER-F16S2G3
5 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 26
Past 30 Days: 97
All Time: 539
