HP G71t-300 Cooling Fan Replacement
  1. HP G71t-300 Cooling Fan Replacement, Keyboard: step 1, image 1 of 3 HP G71t-300 Cooling Fan Replacement, Keyboard: step 1, image 2 of 3 HP G71t-300 Cooling Fan Replacement, Keyboard: step 1, image 3 of 3
    Tool used on this step:
    Anti-Static Wrist Strap
    $7.95
    Buy
    • Ground yourself by either touching an unpainted metal surface or by using the Anti-Static wrist strap.
    • Turn off the computer and remove the charger from the charging port.
    • Turn the laptop over and slide the battery release catch to the right. The battery will pop up from its slot. Remove it using your fingers.
    Ask FixBot
  2. HP G71t-300 Cooling Fan Replacement: step 2, image 1 of 2 HP G71t-300 Cooling Fan Replacement: step 2, image 2 of 2
    • Use a Phillips #0 screwdriver to remove the four screws from the indicated cover.
    • Gently lift and remove the cover.
    Ask FixBot
  3. HP G71t-300 Cooling Fan Replacement: step 3, image 1 of 2 HP G71t-300 Cooling Fan Replacement: step 3, image 2 of 2
    • Remove the five 6mm screws with the Phillips #0 screwdriver.
    Ask FixBot
  4. HP G71t-300 Cooling Fan Replacement: step 4, image 1 of 2 HP G71t-300 Cooling Fan Replacement: step 4, image 2 of 2
    • Pry the keyboard off with a spudger. Be careful not to apply too much pressure and damage any components.
    Ask FixBot
  5. HP G71t-300 Cooling Fan Replacement: step 5, image 1 of 2 HP G71t-300 Cooling Fan Replacement: step 5, image 2 of 2
    • Disconnect the clip attaching the keyboard wiring to the motherboard. Lift and remove the keyboard.
    Ask FixBot
  6. HP G71t-300 Cooling Fan Replacement, Cooling Fan: step 6, image 1 of 3 HP G71t-300 Cooling Fan Replacement, Cooling Fan: step 6, image 2 of 3 HP G71t-300 Cooling Fan Replacement, Cooling Fan: step 6, image 3 of 3
    • Use a Phillips #0 screwdriver to remove the 6mm screw from the top panel.
    • Gently lift and remove the panel. Use a metal spudger if the it seems set in place.
    Ask FixBot
  7. HP G71t-300 Cooling Fan Replacement: step 7, image 1 of 2 HP G71t-300 Cooling Fan Replacement: step 7, image 2 of 2
    • Use a Phillips #0 screwdriver to remove the 6mm screw for the Wi-Fi module cover.
    • Remove the cover.
    Ask FixBot
  8. HP G71t-300 Cooling Fan Replacement: step 8, image 1 of 2 HP G71t-300 Cooling Fan Replacement: step 8, image 2 of 2
    • Remove all fourteen 6mm screws using a Phillips #0 screwdriver.
    Ask FixBot
  9. HP G71t-300 Cooling Fan Replacement: step 9, image 1 of 2 HP G71t-300 Cooling Fan Replacement: step 9, image 2 of 2
    • Partially separate the two panels until connectors are visible.
    • Unclip the wires that attach the trackpad module to the motherboard.
    Ask FixBot
  10. HP G71t-300 Cooling Fan Replacement: step 10, image 1 of 2 HP G71t-300 Cooling Fan Replacement: step 10, image 2 of 2
    • Remove the five highlighted screws using a Phillips #0 screwdriver.
    Ask FixBot
  11. HP G71t-300 Cooling Fan Replacement: step 11, image 1 of 2 HP G71t-300 Cooling Fan Replacement: step 11, image 2 of 2
    • Disconnect the five cables by gently pulling them from their slots.
    Ask FixBot
  12. HP G71t-300 Cooling Fan Replacement: step 12, image 1 of 2 HP G71t-300 Cooling Fan Replacement: step 12, image 2 of 2
    • Press a metal spudger between the VGA port and the plastic housing to pry up the motherboard.
    • Remove the motherboard and turn it so that the fan is facing upward.
    Ask FixBot
  13. HP G71t-300 Cooling Fan Replacement: step 13, image 1 of 3 HP G71t-300 Cooling Fan Replacement: step 13, image 2 of 3 HP G71t-300 Cooling Fan Replacement: step 13, image 3 of 3
    • Use a Phillips #0 screwdriver to loosen the three screws attaching the heatsink to the motherboard.
    • Remove the heatsink and fan assembly by unclipping the fan from the motherboard.
    Ask FixBot
Rohan Mathew
513 Reputation
5 Guides authored
UC Davis, Team 2-3, Oliver Fall 2016 Member of UC Davis, Team 2-3, Oliver Fall 2016
UCD-OLIVER-F16S2G3
5 Members
6 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 10
All Time: 403
