HP G62-234DX Webcam Replacement
    1. HP G62-234DX Webcam Replacement, Screen: step 1, image 1 of 3 HP G62-234DX Webcam Replacement, Screen: step 1, image 2 of 3 HP G62-234DX Webcam Replacement, Screen: step 1, image 3 of 3
      • Make sure the computer is turned off and disconnected from a charger.
      • Place your laptop on a clean, flat surface with the bottom facing up.
      • Slide the battery lock to the left.
      • Slide the battery out from the laptop while holding the lock to the left.
      • Remove the battery.
      Ask FixBot
    2. HP G62-234DX Webcam Replacement: step 2, image 1 of 3 HP G62-234DX Webcam Replacement: step 2, image 2 of 3 HP G62-234DX Webcam Replacement: step 2, image 3 of 3
      • Flip over the laptop and open the laptop.
      • Using a spudger and opening picks, loosen the screen bezel (outer frame).
      • Start from one side of the bezel and work your way around to the other side.
      Ask FixBot
    3. HP G62-234DX Webcam Replacement: step 3, image 1 of 3 HP G62-234DX Webcam Replacement: step 3, image 2 of 3 HP G62-234DX Webcam Replacement: step 3, image 3 of 3
      • Lift the screen bezel with your fingers to reveal the screen unit.
      Ask FixBot
    4. HP G62-234DX Webcam Replacement: step 4, image 1 of 2 HP G62-234DX Webcam Replacement: step 4, image 2 of 2
      • Use a Phillips #0 screwdriver to remove one 4.0 mm screw on the left and right hinges.
      • Lift the hinges with your fingers.
      Ask FixBot
    5. HP G62-234DX Webcam Replacement: step 5, image 1 of 2 HP G62-234DX Webcam Replacement: step 5, image 2 of 2
      • Use a Phillips #0 screwdriver to remove the two 3.0 mm screws on the top of the display.
      Ask FixBot
    6. HP G62-234DX Webcam Replacement: step 6, image 1 of 2 HP G62-234DX Webcam Replacement: step 6, image 2 of 2
      • Use a Phillips #0 screwdriver to remove a total of four 3.0 mm screws along the edge of both sides of the screen.
      Ask FixBot
    7. HP G62-234DX Webcam Replacement: step 7, image 1 of 3 HP G62-234DX Webcam Replacement: step 7, image 2 of 3 HP G62-234DX Webcam Replacement: step 7, image 3 of 3
      • Carefully loosen the adhesive under the screen unit using your spudger.
      • Pull off the screen unit using your fingers.
      • The screen is still connected by the display cable.
      Ask FixBot
    8. HP G62-234DX Webcam Replacement: step 8, image 1 of 3 HP G62-234DX Webcam Replacement: step 8, image 2 of 3 HP G62-234DX Webcam Replacement: step 8, image 3 of 3
      • To disconnect the display cable connector, gently push the tip of a spudger under the clip. Then, swing the clip over to the other side of the socket, so that it lays flat against the cable.
      • Lift the protective film slightly and, holding the clip and cable together, gently pull in the direction of the cable to remove the connector from its socket.
      • Safely remove the screen.
      Ask FixBot
    1. HP G62-234DX Webcam Replacement, Webcam: step 9, image 1 of 3 HP G62-234DX Webcam Replacement, Webcam: step 9, image 2 of 3 HP G62-234DX Webcam Replacement, Webcam: step 9, image 3 of 3
      • Gently unfasten the 6 tabs that hold the webcam cable in place.
      Ask FixBot
    2. HP G62-234DX Webcam Replacement: step 10, image 1 of 1
      • Gently pull the cable off of the display case.
      • It is still connected to the webcam.
      Ask FixBot
    3. HP G62-234DX Webcam Replacement: step 11, image 1 of 3 HP G62-234DX Webcam Replacement: step 11, image 2 of 3 HP G62-234DX Webcam Replacement: step 11, image 3 of 3
      • Pull the bundled cable connector from the webcam in the same direction as the individual wires are running.
      • Pull evenly on the full width of the cable so that no individual wires are overly strained.
      • Use a spudger to remove the webcam from the case.
      Ask FixBot
Kate Ferland
836 Reputation
6 Guides authored
UMass Dartmouth, Team 1-1, Petersen Fall 2023 Member of UMass Dartmouth, Team 1-1, Petersen Fall 2023
UMASSD-PETERSEN-F23S1G1
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 72
All Time: 473
