Up to 20% off select tools
HP G62-234DX RAM Replacement Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
11
Past 30 Days:
58
All Time:
644
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 - 25 minutes
Difficulty: Easy
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
Introduction
Go to step 1 ↓
This guide will explain the process to replace the RAM in the HP G62-234DX.
    1. HP G62-234DX RAM Replacement Replacement, Battery: step 1, image 1 of 1
      • Make sure the computer is turned off, disconnected from the charger, and on a steady surface.
      • Unlock the battery by sliding the button just below it, to the left.
      Ask FixBot
    2. HP G62-234DX RAM Replacement Replacement: step 2, image 1 of 1
      • While pushing the lock button to the unlock position, slide the battery out and away from the laptop.
      • When sliding the new battery back into the socket, you'll know it's secure when you hear a click.
      Ask FixBot
    1. HP G62-234DX RAM Replacement Replacement, RAM: step 3, image 1 of 3 HP G62-234DX RAM Replacement Replacement, RAM: step 3, image 2 of 3 HP G62-234DX RAM Replacement Replacement, RAM: step 3, image 3 of 3
      • Use a Phillips #0 screwdriver to remove three screws from the back panel.
      • Carefully pull the panel off of the back of the laptop to reveal the RAM sticks.
      Ask FixBot
    2. HP G62-234DX RAM Replacement Replacement: step 4, image 1 of 3 HP G62-234DX RAM Replacement Replacement: step 4, image 2 of 3 HP G62-234DX RAM Replacement Replacement: step 4, image 3 of 3
      • Two clips secure the RAM stick in place, one on each side. Using your fingers, spread the clips away from the RAM stick.
      • When released, the RAM stick will pop up at a slight angle.
      • Lift the RAM stick to an angle of about 30 degrees and slide it out.
      • When handling the RAM stick, only touch the outside edges. Take care not to touch the gold-colored contact points along the bottom edge.
      • To install a new RAM stick, slide it in place at about the same angle until it's snug, and then swing it downward until the two clips snap into place.
      Ask FixBot
Author
with
Cameron Popillo
337 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 58
All Time: 644
