HP G62-234DX Hard Drive Replacement
    1. HP G62-234DX Hard Drive Replacement, Battery: step 1, image 1 of 1
      • Make sure the computer is turned off, disconnected from the charger, and on a steady surface.
      • Unlock the battery by sliding the button just below it, to the left.
      Ask FixBot
    2. HP G62-234DX Hard Drive Replacement: step 2, image 1 of 1
      • While pushing the lock button to the unlock position, slide the battery out and away from the laptop.
      • When sliding the new battery back into the socket, you'll know it's secure when you hear a click.
      Ask FixBot
    1. HP G62-234DX Hard Drive Replacement, Hard Drive: step 3, image 1 of 3 HP G62-234DX Hard Drive Replacement, Hard Drive: step 3, image 2 of 3 HP G62-234DX Hard Drive Replacement, Hard Drive: step 3, image 3 of 3
      • It Is recommended to remove the RAM panel for easier access when removing the hard drive panel.
      • Use a Phillips #0 screwdriver to remove the two screws securing the hard drive panel on the back of the laptop.
      • Use a spudger to remove hard drive panel and carefully lift it up and out.
      Ask FixBot
    2. HP G62-234DX Hard Drive Replacement: step 4, image 1 of 1
      • Pull the hard drive from the SATA connector to remove the hard drive from the laptop.
      Ask FixBot
Cameron Popillo
337 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 58
All Time: 616
