HP G62-223CL Wireless Card Replacement
    1. HP G62-223CL Wireless Card Replacement, Battery Removal: step 1, image 1 of 2 HP G62-223CL Wireless Card Replacement, Battery Removal: step 1, image 2 of 2
      • Removing the battery while the laptop is still on may corrupt your files.
      • Turn the device over to expose the bottom of the device.
      • Slide the battery release all the way to the left.
      • There will be a click and the battery will be released from its compartment.
      Ask FixBot
    2. HP G62-223CL Wireless Card Replacement: step 2, image 1 of 1
      • Carefully remove the battery from its compartment.
      Ask FixBot
    1. HP G62-223CL Wireless Card Replacement, Wireless Card: step 3, image 1 of 2 HP G62-223CL Wireless Card Replacement, Wireless Card: step 3, image 2 of 2
      • Locate three Phillips head retaining screws which secure the compartment.
      • Use a Phillips #0 screwdriver to loosen the retaining screws.
      • Remove the panel covering the compartment.
      • Ground yourself before attempting to touch any components. To ground yourself, touch a conductive metal to eliminate any static buildup in your body, which can damage computer components.
      Ask FixBot
    2. HP G62-223CL Wireless Card Replacement: step 4, image 1 of 3 HP G62-223CL Wireless Card Replacement: step 4, image 2 of 3 HP G62-223CL Wireless Card Replacement: step 4, image 3 of 3
      Tool used on this step:
      Buy
      • Use tweezers to disconnect the gray cable and the black cable from the wireless card.
      Ask FixBot
    3. HP G62-223CL Wireless Card Replacement: step 5, image 1 of 1
      • Use a Phillips #0 screwdriver to remove the single 4mm screw from the corner of the wireless card.
      Ask FixBot
    4. HP G62-223CL Wireless Card Replacement: step 6, image 1 of 1
      • Carefully lift and pull wireless card. It is removed!
      Ask FixBot
Garret Layton
687 Reputation
5 Guides authored
USF Tampa, Team 1-4, Sullivan Winter 2015 Member of USF Tampa, Team 1-4, Sullivan Winter 2015
USFT-SULLIVAN-W15S1G4
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 30
Past 30 Days: 109
All Time: 1,597
