Up to 20% off select tools
HP G62-144DX RAM Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
14
Past 30 Days:
85
All Time:
876
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 1 minute
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
This guide will show you how to remove the back panel and replace the 2 RAM modules in the HP G62-144DX.
    1. HP G62-144DX RAM Replacement, Battery: step 1, image 1 of 2 HP G62-144DX RAM Replacement, Battery: step 1, image 2 of 2
      • Make sure to turn off the laptop before removing the battery.
      • Slide the lock to the right, located slightly above the battery location.
      • While pulling the lock, pull the battery out, keeping it flat and parallel to the laptop so that it slides out easily.
      Ask FixBot
    1. HP G62-144DX RAM Replacement, RAM: step 2, image 1 of 3 HP G62-144DX RAM Replacement, RAM: step 2, image 2 of 3 HP G62-144DX RAM Replacement, RAM: step 2, image 3 of 3
      • Unscrew the three Phillips 2.5x6 screws in the L-shaped panel on the back with a Phillips #1 screwdriver.
      • The screws will stay in the panel, but will come loose from the body of the laptop.
      • Use a plastic opening tool to gently pry the panel free from the laptop.
      Ask FixBot
    2. HP G62-144DX RAM Replacement: step 3, image 1 of 3 HP G62-144DX RAM Replacement: step 3, image 2 of 3 HP G62-144DX RAM Replacement: step 3, image 3 of 3
      • Pull the two metal clips to the top RAM module outwards parallel to the laptop.
      • After the RAM module pops up, gently pull in out from the computer.
      • Repeat for the second RAM module.
      Ask FixBot
Author
with
Cameron Moran
644 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 14
Past 30 Days: 85
All Time: 876
