HP G62-144DX Motherboard Replacement
    1. HP G62-144DX Motherboard Replacement, Battery: step 1, image 1 of 2 HP G62-144DX Motherboard Replacement, Battery: step 1, image 2 of 2
      • Make sure to turn off the laptop before removing the battery.
      • Slide the lock to the right, located slightly above the battery location.
      • While pulling the lock, pull the battery out, keeping it flat and parallel to the laptop so that it slides out easily.
      Ask FixBot
    1. HP G62-144DX Motherboard Replacement, Hard Drive: step 2, image 1 of 3 HP G62-144DX Motherboard Replacement, Hard Drive: step 2, image 2 of 3 HP G62-144DX Motherboard Replacement, Hard Drive: step 2, image 3 of 3
      • Loosen the 2 Phillips 2.5x6 screws in the rectangular panel with a Phillips #1 screwdriver.
      • The screws will stay in the panel, but come free from the body of the computer.
      • Gently remove the panel with a plastic opening tool.
      Ask FixBot
    2. HP G62-144DX Motherboard Replacement: step 3, image 1 of 3 HP G62-144DX Motherboard Replacement: step 3, image 2 of 3 HP G62-144DX Motherboard Replacement: step 3, image 3 of 3
      • Unscrew the three 3x4 Phillips screws holding the hard drive in with a Phillips #1 screwdriver.
      • Pull the hard drive cable out of the motherboard.
      • Pull the hard drive out of the computer.
      Ask FixBot
    1. HP G62-144DX Motherboard Replacement, RAM: step 4, image 1 of 3 HP G62-144DX Motherboard Replacement, RAM: step 4, image 2 of 3 HP G62-144DX Motherboard Replacement, RAM: step 4, image 3 of 3
      • Unscrew the three Phillips 2.5x6 screws in the L-shaped panel on the back with a Phillips #1 screwdriver.
      • The screws will stay in the panel, but will come loose from the body of the laptop.
      • Use a plastic opening tool to gently pry the panel free from the laptop.
      Ask FixBot
    2. HP G62-144DX Motherboard Replacement: step 5, image 1 of 3 HP G62-144DX Motherboard Replacement: step 5, image 2 of 3 HP G62-144DX Motherboard Replacement: step 5, image 3 of 3
      • Pull the two metal clips to the top RAM module outwards parallel to the laptop.
      • After the RAM module pops up, gently pull in out from the computer.
      • Repeat for the second RAM module.
      Ask FixBot
    1. HP G62-144DX Motherboard Replacement, Keyboard: step 6, image 1 of 1
      • Remove the 3 Phillips 2.5x5 screws (closest to the battery slot) and the 2 Phillips 2.5x6.5 screws with a Phillips #1 screwdriver.
      • This screws will have a keyboard symbol inscribed next to them.
      Ask FixBot
    2. HP G62-144DX Motherboard Replacement: step 7, image 1 of 3 HP G62-144DX Motherboard Replacement: step 7, image 2 of 3 HP G62-144DX Motherboard Replacement: step 7, image 3 of 3
      • Use the Phillips # 1 screwdriver to unscrew the 2.5x6 Phillips screws holding the L-shaped back panel.
      • Screws should stay in panel, but come free of the laptop body.
      • Gently use a plastic opening tool to remove the panel.
      Ask FixBot
    3. HP G62-144DX Motherboard Replacement: step 8, image 1 of 2 HP G62-144DX Motherboard Replacement: step 8, image 2 of 2
      • Unscrew the final Phillips 2.5x5 keyboard screw with a Phillips #1 screwdriver.
      Ask FixBot
    4. HP G62-144DX Motherboard Replacement: step 9, image 1 of 2 HP G62-144DX Motherboard Replacement: step 9, image 2 of 2
      • Flip the laptop so the top is facing up again and open the cover.
      • Use a metal spudger to pry the keyboard up and pull it back.
      • Be sure to pry up the board itself and not an individual key.
      • This process has the risk of breaking keys.
      Ask FixBot
    5. HP G62-144DX Motherboard Replacement: step 10, image 1 of 2 HP G62-144DX Motherboard Replacement: step 10, image 2 of 2
      • Pull up the latch that connects the keyboard connector the the motherboard.
      Ask FixBot
    1. HP G62-144DX Motherboard Replacement, Motherboard: step 11, image 1 of 2 HP G62-144DX Motherboard Replacement, Motherboard: step 11, image 2 of 2
      • Remove four Phillips PM2.5x3 screws in the battery bay, and remove ten Phillips PM2.5x6.5 screws on the base enclosure with a Phillips #1 screwdriver.
      Ask FixBot
    2. HP G62-144DX Motherboard Replacement: step 12, image 1 of 2 HP G62-144DX Motherboard Replacement: step 12, image 2 of 2
      • Remove the Phillips PM2.0×3.0 screw that secures the WLAN module to the computer with a Phillips #0 screwdriver.
      Ask FixBot
    3. HP G62-144DX Motherboard Replacement: step 13, image 1 of 3 HP G62-144DX Motherboard Replacement: step 13, image 2 of 3 HP G62-144DX Motherboard Replacement: step 13, image 3 of 3
      • Disconnect the two wires that attach the card to the motherboard by pulling them up individually.
      • Grab the card gently and pull it out after it pops up.
      Ask FixBot
    4. HP G62-144DX Motherboard Replacement: step 14, image 1 of 3 HP G62-144DX Motherboard Replacement: step 14, image 2 of 3 HP G62-144DX Motherboard Replacement: step 14, image 3 of 3
      • Flip the laptop over so that the top is facing upwards.
      • Remove the Phillips PM2.5×6.0 screw that secures the top cover to the computer with a Phillips #1 screwdriver.
      • Disconnect the 4 connectors to the motherboard.
      Ask FixBot
    5. HP G62-144DX Motherboard Replacement: step 15, image 1 of 2 HP G62-144DX Motherboard Replacement: step 15, image 2 of 2
      • Take off the cover by prying open the cover with a plastic opening tool.
      • Lift the edge near the display first until it pops out, and then remove the cover by pulling it out.
      • The cover should come out with ease. If you having trouble pulling the cover out you should double check to see if any screws were left unscrew.
      Ask FixBot
    6. HP G62-144DX Motherboard Replacement: step 16, image 1 of 3 HP G62-144DX Motherboard Replacement: step 16, image 2 of 3 HP G62-144DX Motherboard Replacement: step 16, image 3 of 3
      • Remove the two motherboard screws and the fan screw that holds it on the the rest of the computer with a Phillips #1 screwdriver.
      Ask FixBot
    7. HP G62-144DX Motherboard Replacement: step 17, image 1 of 3 HP G62-144DX Motherboard Replacement: step 17, image 2 of 3 HP G62-144DX Motherboard Replacement: step 17, image 3 of 3
      • Remove the six connectors from the motherboard.
      • The power connector is located underneth the USB connector.
      Ask FixBot
    8. HP G62-144DX Motherboard Replacement: step 18, image 1 of 1
      • Lift up the right side of the motherboard and pull it out to the right carefully.
      Ask FixBot
Cameron Moran
623 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 11
Past 30 Days: 31
All Time: 1,247
