Up to 20% off select tools
HP G62-144DX Keyboard Replacement
Views: 1.3K
View statistics:
Past 24 Hours:
3
Past 7 Days:
18
Past 30 Days:
96
All Time:
1,274
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
The keyboard may not be working for a variety of reasons and may need to be replaced.
    1. HP G62-144DX Keyboard Replacement, Battery: step 1, image 1 of 2 HP G62-144DX Keyboard Replacement, Battery: step 1, image 2 of 2
      • Make sure to turn off the laptop before removing the battery.
      • Slide the lock to the right, located slightly above the battery location.
      • While pulling the lock, pull the battery out, keeping it flat and parallel to the laptop so that it slides out easily.
      Ask FixBot
    1. HP G62-144DX Keyboard Replacement, Keyboard: step 2, image 1 of 1
      • Remove the 3 Phillips 2.5x5 screws (closest to the battery slot) and the 2 Phillips 2.5x6.5 screws with a Phillips #1 screwdriver.
      • This screws will have a keyboard symbol inscribed next to them.
      Ask FixBot
    2. HP G62-144DX Keyboard Replacement: step 3, image 1 of 3 HP G62-144DX Keyboard Replacement: step 3, image 2 of 3 HP G62-144DX Keyboard Replacement: step 3, image 3 of 3
      • Use the Phillips # 1 screwdriver to unscrew the 2.5x6 Phillips screws holding the L-shaped back panel.
      • Screws should stay in panel, but come free of the laptop body.
      • Gently use a plastic opening tool to remove the panel.
      Ask FixBot
    3. HP G62-144DX Keyboard Replacement: step 4, image 1 of 2 HP G62-144DX Keyboard Replacement: step 4, image 2 of 2
      • Unscrew the final Phillips 2.5x5 keyboard screw with a Phillips #1 screwdriver.
      Ask FixBot
    4. HP G62-144DX Keyboard Replacement: step 5, image 1 of 2 HP G62-144DX Keyboard Replacement: step 5, image 2 of 2
      • Flip the laptop so the top is facing up again and open the cover.
      • Use a metal spudger to pry the keyboard up and pull it back.
      • Be sure to pry up the board itself and not an individual key.
      • This process has the risk of breaking keys.
      Ask FixBot
    5. HP G62-144DX Keyboard Replacement: step 6, image 1 of 2 HP G62-144DX Keyboard Replacement: step 6, image 2 of 2
      • Pull up the latch that connects the keyboard connector the the motherboard.
      Ask FixBot
3 other people completed this guide.
Author
with
Cameron Moran
644 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 18
Past 30 Days: 96
All Time: 1,274
