HP G62 347NR Keyboard Replacement
    1. HP G62 347NR Keyboard Replacement, Keyboard: step 1, image 1 of 1
      • Make sure the device is turned off before removing the battery to avoid loss or corruption of files.
      • Turn the device over so the bottom is facing up.
      • Slide the battery release to the left until you hear a click.
      • Once you hear a click, the battery will have been released from the battery compartment.
      Ask FixBot
    2. HP G62 347NR Keyboard Replacement: step 2, image 1 of 1
      • Remove the battery, carefully, from the compartment.
      Ask FixBot
    3. HP G62 347NR Keyboard Replacement: step 3, image 1 of 2 HP G62 347NR Keyboard Replacement: step 3, image 2 of 2
      • Find the hard drive compartment with two Phillips head screws.
      • Use the PH1 screwdriver to loosen and remove both screws.
      • Gently remove the hard drive compartment.
      Ask FixBot
    4. HP G62 347NR Keyboard Replacement: step 4, image 1 of 2 HP G62 347NR Keyboard Replacement: step 4, image 2 of 2
      • Locate the three Phillips head screws on the compartment with the wifi and keyboard logos.
      • Using the Phillips #1 screwdriver, remove the three screws.
      Ask FixBot
    5. HP G62 347NR Keyboard Replacement: step 5, image 1 of 2 HP G62 347NR Keyboard Replacement: step 5, image 2 of 2
      • Locate the two keyboard logos on back of the computer.
      • Find the Phillips head screws in the hole next to the logo.
      • Remove the two screws using a Phillips #1 screwdriver.
      Ask FixBot
    6. HP G62 347NR Keyboard Replacement: step 6, image 1 of 2 HP G62 347NR Keyboard Replacement: step 6, image 2 of 2
      • In the battery compartment, locate the three keyboard logos.
      • Find the Phillips head screws next to each logo.
      • Remove the three screws using the Phillips #1 screwdriver.
      Ask FixBot
    7. HP G62 347NR Keyboard Replacement: step 7, image 1 of 2 HP G62 347NR Keyboard Replacement: step 7, image 2 of 2
      • Place the plastic opening tool between the keyboard and the motherboard.
      • Gently pry the entire keyboard up and away from the laptop's motherboard.
      • Once you have part of the keyboard separated, run your fingers around the edge of the keyboard to separate the entire thing.
      Ask FixBot
4 other people completed this guide.
McKenzi Morris
535 Reputation
3 Guides authored
Texas Tech, Team 6-1, Bennett Fall 2016 Member of Texas Tech, Team 6-1, Bennett Fall 2016
TTU-BENNETT-F16S6G1
3 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 25
Past 30 Days: 113
All Time: 3,403
