HP G62 347NR CD/DVD Drive Replacement
    1. HP G62 347NR  CD/DVD Drive Replacement, CD/DVD Drive: step 1, image 1 of 1
      • Make sure the device is turned off before removing the battery to avoid loss or corruption of files.
      • Turn the device over so the bottom is facing up.
      • Slide the battery release to the left until you hear a click.
      • Once you hear a click, the battery will have been released from the battery compartment.
      Ask FixBot
    2. HP G62 347NR  CD/DVD Drive Replacement: step 2, image 1 of 1
      • Remove the battery, carefully, from the compartment.
      Ask FixBot
    3. HP G62 347NR  CD/DVD Drive Replacement: step 3, image 1 of 1
      • Find the hard drive compartment with two Phillips head screws.
      • Use the PH1 screwdriver to loosen and remove both screws.
      • Gently remove the hard drive compartment.
      Ask FixBot
    4. HP G62 347NR  CD/DVD Drive Replacement: step 4, image 1 of 1
      • On the far left of the hard drive compartment, find the Phillips head screw.
      • Remove the Phillips head screw with the PH1 screwdriver.
      Ask FixBot
    5. HP G62 347NR  CD/DVD Drive Replacement: step 5, image 1 of 2 HP G62 347NR  CD/DVD Drive Replacement: step 5, image 2 of 2
      • Get the plastic opening tool and place it between the laptop and the CD/DVD drive. Place it toward the center of the drive for maximum support.
      • Carefully pry the CD/DVD drive open.
      • Slide the CD/DVD drive out once it is pried open.
      Ask FixBot
McKenzi Morris
535 Reputation
3 Guides authored
Texas Tech, Team 6-1, Bennett Fall 2016 Member of Texas Tech, Team 6-1, Bennett Fall 2016
TTU-BENNETT-F16S6G1
3 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 25
Past 30 Days: 108
All Time: 1,051
