HP G60-443CL Hard Drive Replacement
    1. HP G60-443CL Hard Drive Replacement, Battery: step 1, image 1 of 1
      • Place the laptop upside down where the headphone and auxiliary jack are facing you.
      Ask FixBot
    2. HP G60-443CL Hard Drive Replacement: step 2, image 1 of 1
      • In the top left corner, there is a lever that has a small picture of a battery on it. Slide the lever to the left.
      Ask FixBot
    3. HP G60-443CL Hard Drive Replacement: step 3, image 1 of 1
      • Once you have slid the lever to the left, the front part of the battery will be released and you should be able to grab the released part of the battery with your thumb.
      Ask FixBot
    4. HP G60-443CL Hard Drive Replacement: step 4, image 1 of 1
      • The battery can then be pulled out of its compartment by hand.
      Ask FixBot
    1. HP G60-443CL Hard Drive Replacement, Hard Drive: step 5, image 1 of 1
      • Once the battery has been removed, locate the 5mm Phillips #0 screws on the bottom right panel.
      • Remove the 5mm Phillips #0 screws using the Phillips #0 Screwdriver.
      • Next, remove the panel that was attached to the screws, leaving the hard drive exposed.
      Ask FixBot
    2. HP G60-443CL Hard Drive Replacement: step 6, image 1 of 1
      • After the panel has been removed, use the screwdriver to remove the three 3mm Phillips #0 screws attached to the hard drive.
      Ask FixBot
    3. HP G60-443CL Hard Drive Replacement: step 7, image 1 of 1
      • Once the screws attached to the hard drive are removed, you will be able to take the hard drive out of the compartment.
      Ask FixBot
Larissa Moreno-Trejo
108 Reputation
1 Guide authored
Baylor, Team S8-G7, Johnson Fall 2017 Member of Baylor, Team S8-G7, Johnson Fall 2017
BU-JOHNSON-F17S8G7
3 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 93
All Time: 1,552
