HP G60 Wi-Fi Card Replacement
    1. HP G60 Wi-Fi Card Replacement, Battery: step 1, image 1 of 3 HP G60 Wi-Fi Card Replacement, Battery: step 1, image 2 of 3 HP G60 Wi-Fi Card Replacement, Battery: step 1, image 3 of 3
      • First, remove the battery to avoid electric shock
      • Slide and unlock the battery, then lift it
      Ask FixBot
    2. HP G60 Wi-Fi Card Replacement, Wi-Fi card: step 2, image 1 of 3 HP G60 Wi-Fi Card Replacement, Wi-Fi card: step 2, image 2 of 3 HP G60 Wi-Fi Card Replacement, Wi-Fi card: step 2, image 3 of 3
      • Now, you should to remove the Wi-Fi card cover
      • Remove this screw
      • Lift the cover
      Ask FixBot
    3. HP G60 Wi-Fi Card Replacement, Unlock Wi-Fi card: step 3, image 1 of 3 HP G60 Wi-Fi Card Replacement, Unlock Wi-Fi card: step 3, image 2 of 3 HP G60 Wi-Fi Card Replacement, Unlock Wi-Fi card: step 3, image 3 of 3
      • The Wi-Fi card is locked, but you should to change that.
      • Remove this two little screws.
      • Pull the Wi-Fi card.
      Ask FixBot
    4. HP G60 Wi-Fi Card Replacement, Unplug Wi-Fi card: step 4, image 1 of 3 HP G60 Wi-Fi Card Replacement, Unplug Wi-Fi card: step 4, image 2 of 3 HP G60 Wi-Fi Card Replacement, Unplug Wi-Fi card: step 4, image 3 of 3
      • You should to be carefull with the next steps, the plugs are easy to separate, but they are fragile
      • Pull carefully both cables from the Wi-Fi card, it requires a little strength
      Ask FixBot
    5. HP G60 Wi-Fi Card Replacement, Reassemble Wi-Fi card: step 5, image 1 of 2 HP G60 Wi-Fi Card Replacement, Reassemble Wi-Fi card: step 5, image 2 of 2
      • Now it's time to put the new Wi-Fi card
      • Connect both plugs, the cable with white tag, at the left of the Wi-Fi card, the green one, at the right plug
      Ask FixBot
    6. HP G60 Wi-Fi Card Replacement, Data Plug: step 6, image 1 of 3 HP G60 Wi-Fi Card Replacement, Data Plug: step 6, image 2 of 3 HP G60 Wi-Fi Card Replacement, Data Plug: step 6, image 3 of 3
      • The Wi-Fi card already has the power plugs, now it's time to the data plug
      • Insert the Wi-Fi card in a 45 degrees angle
      • Now press it and screw it
      Ask FixBot
    7. HP G60 Wi-Fi Card Replacement, Reassemble cover: step 7, image 1 of 3 HP G60 Wi-Fi Card Replacement, Reassemble cover: step 7, image 2 of 3 HP G60 Wi-Fi Card Replacement, Reassemble cover: step 7, image 3 of 3
      • For finish, reassemble the cover
      • If the cover is still lifted, press softly until you hear a click
      Ask FixBot
Finish Line
8 other people completed this guide.
jimenezser
3,905 Reputation
4 Guides authored
4 Guide Comments
If the button that turns blue when I start my computer stays orange does that mean I need to install a new wifi card?
veronica - Reply Share
Hi frnd just want to know ur hp laptop button was not working it stayed orange thn what did u do? U changed wifi card or button plz reply me i have same condition can u ans me on my mobile whatsapp plz +85254077440
saqib raheem - Reply Share
Please provide information on the model of the wifi card
thaisabs - Reply Share
My card wifi on laptop G60-530US was not working. Can you suggest me some modle of new card wifi which can be suitable my laptop. Thanks so much
tech - Reply Share
Past 24 Hours: 3
Past 7 Days: 29
Past 30 Days: 116
All Time: 4,574
