HP Folio 13t-1000 RAM Replacement
    1. HP Folio 13t-1000 RAM Replacement, Keyboard: step 1, image 1 of 2 HP Folio 13t-1000 RAM Replacement, Keyboard: step 1, image 2 of 2
      • Use an antistatic wrist wrap, or periodically touch unpainted metal to minimize the risk of damaging the laptop by electrostatic shock.
      • Use a PH1 screw head to remove the 16, 6mm screws from the bottom case housing of the laptop.
      Ask FixBot
    2. HP Folio 13t-1000 RAM Replacement: step 2, image 1 of 3 HP Folio 13t-1000 RAM Replacement: step 2, image 2 of 3 HP Folio 13t-1000 RAM Replacement: step 2, image 3 of 3
      • This step requires unlocking the very fragile plastic clips along the frame; take care not to damage them.
      • Slide the spudger with a twisting motion along the entire perimeter of the laptop until the top cover is separated from the frame of the device.
      Ask FixBot
    3. HP Folio 13t-1000 RAM Replacement: step 3, image 1 of 1
      • Using the flat portion of the plastic spudger, push the corner of the black surface until the first clip unlocks.
      • The top right corner of the keyboard should now be sticking out slightly.
      • Repeat the same process for the top left corner.
      Ask FixBot
    4. HP Folio 13t-1000 RAM Replacement: step 4, image 1 of 2 HP Folio 13t-1000 RAM Replacement: step 4, image 2 of 2
      • Slide the keyboard up and towards the screen just enough to separate the keyboard from the top cover.
      Ask FixBot
    5. HP Folio 13t-1000 RAM Replacement: step 5, image 1 of 3 HP Folio 13t-1000 RAM Replacement: step 5, image 2 of 3 HP Folio 13t-1000 RAM Replacement: step 5, image 3 of 3
      • To unlock the clamps connected to the motherboard, use your fingers or insert the pointed edge of the spudger between the first clamp and the cable.
      • Repeat the same process for the second clamp.
      Ask FixBot
    6. HP Folio 13t-1000 RAM Replacement: step 6, image 1 of 3 HP Folio 13t-1000 RAM Replacement: step 6, image 2 of 3 HP Folio 13t-1000 RAM Replacement: step 6, image 3 of 3
      • Remove the keyboard from the laptop.
      Ask FixBot
    1. HP Folio 13t-1000 RAM Replacement, Top Hardware Cover: step 7, image 1 of 3 HP Folio 13t-1000 RAM Replacement, Top Hardware Cover: step 7, image 2 of 3 HP Folio 13t-1000 RAM Replacement, Top Hardware Cover: step 7, image 3 of 3
      • Place your finger between one of the plastic clamps and the cable and apply a slight leveraging force until the clamp pops up.
      • Do the same for the second connection.
      Ask FixBot
    2. HP Folio 13t-1000 RAM Replacement: step 8, image 1 of 2 HP Folio 13t-1000 RAM Replacement: step 8, image 2 of 2
      • Remove the top hardware cover.
      Ask FixBot
    1. HP Folio 13t-1000 RAM Replacement, RAM: step 9, image 1 of 1
      • Using the tips of your fingers, gently apply opposite outward force until the two clips are no longer holding the RAM stick.
      Ask FixBot
    2. HP Folio 13t-1000 RAM Replacement: step 10, image 1 of 1
      • Carefully remove the old RAM by sliding it towards the screen.
      Ask FixBot
Cody Badchkam
112 Reputation
4 Guides authored
USF Tampa, Team 1-2, Cagle Fall 2016 Member of USF Tampa, Team 1-2, Cagle Fall 2016
USFT-CAGLE-F16S1G2
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 19
Past 30 Days: 105
All Time: 931
