Up to 20% off select tools
HP Flyer Red Optical Disc Drive Replacement
Views: 1.5K
View statistics:
Past 24 Hours:
3
Past 7 Days:
18
Past 30 Days:
89
All Time:
1,514
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Very easy
Tools
Introduction
Go to step 1 ↓
This guide is a step by step instruction on how to replace your optical disc drive. You may need to do this if your laptop is not reading disks or if it is damaging them.
    1. HP Flyer Red Optical Disc Drive Replacement, Battery: step 1, image 1 of 2 HP Flyer Red Optical Disc Drive Replacement, Battery: step 1, image 2 of 2
      • Make sure your laptop is powered off.
      • With laptop closed flip to look at the underside of the laptop.
      Ask FixBot
    2. HP Flyer Red Optical Disc Drive Replacement: step 2, image 1 of 1
      • On the underside of the laptop towards the hinge for the screen there are two rectangular slide switches located inside of rectangular tracks.
      Ask FixBot
    3. HP Flyer Red Optical Disc Drive Replacement: step 3, image 1 of 2 HP Flyer Red Optical Disc Drive Replacement: step 3, image 2 of 2
      • The left switch is the battery unlock switch.
      • Inside the rectangular track of this switch there is an image of a closed lock that should be visible. Push this switch to the other end of the track and an image of an open lock should be visible.
      Ask FixBot
    4. HP Flyer Red Optical Disc Drive Replacement: step 4, image 1 of 1
      • Then take and slide the other switch to the other end of its track which will pop out the battery.
      • Grab the battery and pull it out of the slot.
      Ask FixBot
    1. HP Flyer Red Optical Disc Drive Replacement, Optical Disc Drive: step 5, image 1 of 1
      • Remove the 4mm Phillips #1 screw located towards the middle of the laptop slightly towards the right with the picture of the CD next to it.
      Ask FixBot
    2. HP Flyer Red Optical Disc Drive Replacement: step 6, image 1 of 2 HP Flyer Red Optical Disc Drive Replacement: step 6, image 2 of 2
      • Slide the disc tray out of the its slot.
      Ask FixBot
2 other people completed this guide.
Author
with
Anthony Ciotti
783 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 18
Past 30 Days: 89
All Time: 1,514
