Introduction
This guide is helpful if you have something wrong with your hard drive and you need to replace it.
Remove the 4mm Phillips #1 screw located towards the middle of the laptop slightly towards the right with the picture of the CD next to it.
Next locate and unscrew the two 4mm Phllips #1 screws with the keyboard symbol located towards the middle and top of the bottom of the laptop.
Next turn the laptop over and flip open the screen.
Use the plastic opening tool to pry the keyboard upwards from the bottom right hand corner of the keyboard.
Use another plastic opening tool with the first plastic opening tool you placed to undo every plastic clasp surrounding the keyboard.
After removing the keyboard close the laptop and flip it over.
Using a spudger to remove the rubber bumpers located at the top left and top right of the laptop.
10 other people completed this guide.
