Up to 20% off select tools
HP Flyer Red Battery Replacement
Views: 3.1K
View statistics:
Past 24 Hours:
4
Past 7 Days:
18
Past 30 Days:
89
All Time:
3,069
Comments: 1
1 guide comment.
Go to guide comments
Completed: 7
7 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 2 minutes
Difficulty: Very easy
Introduction
Go to step 1 ↓
We will show step by step progression of how to unlock the battery and remove it. This guide will help you understand the fundamentals of a battery replacement with this HP laptop. This guide is useful if you have a new battery and are looking to swap it out with the old one.
    1. HP Flyer Red Battery Replacement, Battery: step 1, image 1 of 2 HP Flyer Red Battery Replacement, Battery: step 1, image 2 of 2
      • Make sure your laptop is powered off.
      • With laptop closed flip to look at the underside of the laptop.
      Ask FixBot
    2. HP Flyer Red Battery Replacement: step 2, image 1 of 1
      • On the underside of the laptop towards the hinge for the screen there are two rectangular slide switches located inside of rectangular tracks.
      Ask FixBot
    3. HP Flyer Red Battery Replacement: step 3, image 1 of 2 HP Flyer Red Battery Replacement: step 3, image 2 of 2
      • The left switch is the battery unlock switch.
      • Inside the rectangular track of this switch there is an image of a closed lock that should be visible. Push this switch to the other end of the track and an image of an open lock should be visible.
      Ask FixBot
    4. HP Flyer Red Battery Replacement: step 4, image 1 of 1
      • Then take and slide the other switch to the other end of its track which will pop out the battery.
      • Grab the battery and pull it out of the slot.
      Ask FixBot
7 other people completed this guide.
Author
with
Anthony Ciotti
783 Reputation
5 Guides authored
1 Guide Comment
What do you do when the battery not charging but the laptop is working when directly plugged on power
liberty siegmann derera - Reply Share
Past 24 Hours: 4
Past 7 Days: 18
Past 30 Days: 89
All Time: 3,069
