HP Envy x360 m6-aq103dx Wireless Module Replacement
Views: 1.7K
View statistics:
Past 24 Hours:
Past 7 Days:
21
Past 30 Days:
92
All Time:
1,676
Comments: 6
5 comments on steps, 1 guide comment.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide is for the replacement of the Wireless Module. You will need a small plastic opening tool and a standard Phillips Head 1 Screwdriver.
Tools
    1. HP Envy x360 m6-aq103dx Wireless Module Replacement, Bottom Cover: step 1, image 1 of 3 HP Envy x360 m6-aq103dx Wireless Module Replacement, Bottom Cover: step 1, image 2 of 3 HP Envy x360 m6-aq103dx Wireless Module Replacement, Bottom Cover: step 1, image 3 of 3
      • Flip the laptop over to expose the underside.
      • Remove the two grip pads with blue plastic opening tool by inserting the tool between the laptop and the pads and slowly lifting up.
      • The grip pads are tacky, remove slowly to avoid separating the adhesive.
      Ask FixBot
    2. HP Envy x360 m6-aq103dx Wireless Module Replacement: step 2, image 1 of 1
      • Remove the two 8 mm Phillips Head screws that were under the grip pads using a Phillip's Head 1 Screwdriver.
      Ask FixBot
    3. HP Envy x360 m6-aq103dx Wireless Module Replacement: step 3, image 1 of 1
      • Remove the six 5 mm Torx screws using a T5 Torx Screwdriver.
      Ask FixBot
    4. HP Envy x360 m6-aq103dx Wireless Module Replacement: step 4, image 1 of 3 HP Envy x360 m6-aq103dx Wireless Module Replacement: step 4, image 2 of 3 HP Envy x360 m6-aq103dx Wireless Module Replacement: step 4, image 3 of 3
      • Use the nylon spudger to pop off the bottom cover by inserting it into the heat vent and twisting to the left or right.
      • You may hear a slight clicking or popping, but that is normal.
      Ask FixBot
    1. HP Envy x360 m6-aq103dx Wireless Module Replacement, Battery: step 5, image 1 of 2 HP Envy x360 m6-aq103dx Wireless Module Replacement, Battery: step 5, image 2 of 2
      • Use the Phillips Head 1 Screwdriver to remove the six 4 mm screws.
      Ask FixBot
    2. HP Envy x360 m6-aq103dx Wireless Module Replacement: step 6, image 1 of 3 HP Envy x360 m6-aq103dx Wireless Module Replacement: step 6, image 2 of 3 HP Envy x360 m6-aq103dx Wireless Module Replacement: step 6, image 3 of 3
      • Disconnect the battery port from the motherboard by gently lifting it on both sides with the plastic opening tool.
      • Lift up the port with the tool.
      Ask FixBot
    3. HP Envy x360 m6-aq103dx Wireless Module Replacement: step 7, image 1 of 3 HP Envy x360 m6-aq103dx Wireless Module Replacement: step 7, image 2 of 3 HP Envy x360 m6-aq103dx Wireless Module Replacement: step 7, image 3 of 3
      • Lift the battery out of the laptop with your hands.
      Ask FixBot
    1. HP Envy x360 m6-aq103dx Wireless Module Replacement, Intel Wireless Module: step 8, image 1 of 3 HP Envy x360 m6-aq103dx Wireless Module Replacement, Intel Wireless Module: step 8, image 2 of 3 HP Envy x360 m6-aq103dx Wireless Module Replacement, Intel Wireless Module: step 8, image 3 of 3
      • Remove the two antenna cables connected to the wireless module by wedging the small plastic opening tool between the cables and the wireless module and lifting up.
      Ask FixBot
    2. HP Envy x360 m6-aq103dx Wireless Module Replacement: step 9, image 1 of 1
      • Remove the 3.5 mm Phillips Head screw with the Phillip Head 1 screwdriver.
      Ask FixBot
    3. HP Envy x360 m6-aq103dx Wireless Module Replacement: step 10, image 1 of 3 HP Envy x360 m6-aq103dx Wireless Module Replacement: step 10, image 2 of 3 HP Envy x360 m6-aq103dx Wireless Module Replacement: step 10, image 3 of 3
      • Slide the wireless module towards the back of the computer to remove it.
      Ask FixBot
2 other people completed this guide.
Joey Chen
316 Reputation
2 Guides authored
Cal Poly, Team S4-G3, Livingston Fall 2017 Member of Cal Poly, Team S4-G3, Livingston Fall 2017
CPSU-LIVINGSTON-F17S4G3
4 Members
108 Guides authored
1 Guide Comment
@jchen202 Just curious, what is the Battery Wattage of this HP Envy? I noticed your guide contains a glimpse of the DC IN CONNECTOR , which seems to be identical to my HP ENVY X360 - 15M-BP112DX. How idid your repairs turn out? If possible, would you be able to provide a picture of the DC IN Connector?
Al N - Reply Share
Past 24 Hours: 1
Past 7 Days: 21
Past 30 Days: 92
All Time: 1,676
