HP Envy x360 15m-cn0012dx Fan Replacement
    1. HP Envy x360 15m-cn0012dx  Fan Replacement, Fan: step 1, image 1 of 2 HP Envy x360 15m-cn0012dx  Fan Replacement, Fan: step 1, image 2 of 2
      • Make sure the computer is turned off, and remove all cables.
      • Set the laptop face down.
      • Peel back the grey screw guards, along the top and bottom edge of the back case. It may be helpful to use a spudger to get started.
      • Peel slowly to avoid tearing the rubber covers.
      Ask FixBot
    2. HP Envy x360 15m-cn0012dx  Fan Replacement: step 2, image 1 of 3 HP Envy x360 15m-cn0012dx  Fan Replacement: step 2, image 2 of 3 HP Envy x360 15m-cn0012dx  Fan Replacement: step 2, image 3 of 3
      • Using the Phillips #0 screwdriver, remove the seven 5mm screws from the back case.
      Ask FixBot
    3. HP Envy x360 15m-cn0012dx  Fan Replacement: step 3, image 1 of 3 HP Envy x360 15m-cn0012dx  Fan Replacement: step 3, image 2 of 3 HP Envy x360 15m-cn0012dx  Fan Replacement: step 3, image 3 of 3
      • Pry open the back cover using the iFixit Opening Tool.
      • While using the tool, place a pick at each corner of the computer (be careful and do it slowly).
      • Once all the corners are slightly lifted, carefully pop off the back cover.
      Ask FixBot
    4. HP Envy x360 15m-cn0012dx  Fan Replacement: step 4, image 1 of 3 HP Envy x360 15m-cn0012dx  Fan Replacement: step 4, image 2 of 3 HP Envy x360 15m-cn0012dx  Fan Replacement: step 4, image 3 of 3
      • Remove the two 4mm screws from the fan using a Phillips #0 screwdriver.
      • Peel the tape off of the multicolor cable bundle connecting the fan to the motherboard.
      • Use the iFixit opening tool to disconnect the connector.
      Ask FixBot
    5. HP Envy x360 15m-cn0012dx  Fan Replacement: step 5, image 1 of 2 HP Envy x360 15m-cn0012dx  Fan Replacement: step 5, image 2 of 2
      • Peel back the tape from the heatsink.
      • Use the Phillips #0 screwdriver to remove the four captive screws from the heatsink.
      • These screws will stay inside the heatsink while it is removed, simply loosen them until they disengage from the case and the heatsink becomes loose.
      Ask FixBot
    6. HP Envy x360 15m-cn0012dx  Fan Replacement: step 6, image 1 of 2 HP Envy x360 15m-cn0012dx  Fan Replacement: step 6, image 2 of 2
      • Unlatch the black cable from the plastic guides on the fan.
      • Lift the fan from the laptop case.
      Ask FixBot
2 other people completed this guide.
Ross Jeseritz
157 Reputation
1 Guide authored
UW Stout, Team S1-G3, Schneider-Bateman Spring 2020 Member of UW Stout, Team S1-G3, Schneider-Bateman Spring 2020
UWSTOUT-SCHNEIDER-BATEMAN-S20S1G3
3 Members
59 Guides authored
2 Guide Comments
You didn't show how to remove the Fan. You removed the Fan and Heat Sink. There's 4 more screws. Finish the job.
philw395 - Reply Share
Uh, this video is not complete. You have to remove the four very tiny screws that hold the fan into the fan enclosure, replace the fan, and replace those four screws (very precise work to get those screws back in).
Also left out the reapplication of thermal grease between the heat sink and the processor.
Steven Scharf - Reply Share
Past 24 Hours: 5
Past 7 Days: 14
Past 30 Days: 63
All Time: 4,220
