HP Envy x360 15-u473cl RAM Replacement
    1. HP Envy x360 15-u473cl RAM  Replacement, Battery: step 1, image 1 of 2 HP Envy x360 15-u473cl RAM  Replacement, Battery: step 1, image 2 of 2
      • Power off your laptop before beginning disassembly.
      • Pry off the 2 rear rubber pads (closest to the laptop hinge) using the plastic opening tool to reveal two screws.
      • Remove the 2 anti-tamper proof covers using the spudger to reveal two screws.
      Ask FixBot
    2. HP Envy x360 15-u473cl RAM  Replacement: step 2, image 1 of 1
      • Remove the fourteen 7mm screws using the Phillips #0 screwdriver from the bottom of the laptop.
      Ask FixBot
    3. HP Envy x360 15-u473cl RAM  Replacement: step 3, image 1 of 2 HP Envy x360 15-u473cl RAM  Replacement: step 3, image 2 of 2
      • Turn the device right side up and open the lid.
      • Insert the plastic opening tool in between the keyboard plate and the base of laptop.
      • Run the tool along seem, prying up as you go.
      • Separate the keyboard plate from the base, lifting from the front.
      Ask FixBot
    4. HP Envy x360 15-u473cl RAM  Replacement: step 4, image 1 of 1
      • There are 3 ribbon cables (black, white, and copper color) connecting the computer to the keyboard plate. Disconnect the 3 ribbon cables using the plastic opening tool by prying up the latches holding each cable in place.
      • Remove the keyboard plate from the device.
      Ask FixBot
    5. HP Envy x360 15-u473cl RAM  Replacement: step 5, image 1 of 1
      • Remove the thick white ribbon cable covering the battery using the plastic opening tool by prying up the latches attaching each end.
      Ask FixBot
    6. HP Envy x360 15-u473cl RAM  Replacement: step 6, image 1 of 1
      • Remove the three 4mm screws using the Phillips #0 screwdriver.
      Ask FixBot
    7. HP Envy x360 15-u473cl RAM  Replacement: step 7, image 1 of 1
      • Disconnect the battery from the motherboard.
      • There may be tamper-proof tape holding the battery in place. Remove the tape if present.
      • Remove the battery from the device.
      Ask FixBot
    1. HP Envy x360 15-u473cl RAM  Replacement, Fan: step 8, image 1 of 1
      • Remove the three 4mm screws using the Phillips #0 screwdriver from the device fan.
      Ask FixBot
    2. HP Envy x360 15-u473cl RAM  Replacement: step 9, image 1 of 2 HP Envy x360 15-u473cl RAM  Replacement: step 9, image 2 of 2
      • Disconnect the fan from the motherboard using the spudger.
      • Remove the fan from the device.
      Ask FixBot
    1. HP Envy x360 15-u473cl RAM  Replacement, Motherboard: step 10, image 1 of 2 HP Envy x360 15-u473cl RAM  Replacement, Motherboard: step 10, image 2 of 2
      • Remove the five 4mm screws with the Phillips #0 screwdriver.
      • Remove one 3mm screw with the Phillips #00 screwdriver.
      Ask FixBot
    2. HP Envy x360 15-u473cl RAM  Replacement: step 11, image 1 of 2 HP Envy x360 15-u473cl RAM  Replacement: step 11, image 2 of 2
      • Disconnect the 2 white ribbon cables using the plastic opening tool.
      • Disconnect the two black cable bundles using the plastic opening tool.
      Ask FixBot
    3. HP Envy x360 15-u473cl RAM  Replacement: step 12, image 1 of 3 HP Envy x360 15-u473cl RAM  Replacement: step 12, image 2 of 3 HP Envy x360 15-u473cl RAM  Replacement: step 12, image 3 of 3
      • Disconnect the charging port wire bundle from the motherboard using the plastic opening tool.
      • Disconnect the wireless card by pulling away from the black transistor using the spudger.
      • Remove the motherboard.
      Ask FixBot
    1. HP Envy x360 15-u473cl RAM  Replacement, RAM: step 13, image 1 of 3 HP Envy x360 15-u473cl RAM  Replacement, RAM: step 13, image 2 of 3 HP Envy x360 15-u473cl RAM  Replacement, RAM: step 13, image 3 of 3
      • Use both fingers to push the tabs to the side and release the RAM.
      • Remove the RAM chip by pulling away from the connector.
      • Repeat the procedure for the second RAM chip.
      Ask FixBot
2 other people completed this guide.
Matthew Ortman
169 Reputation
2 Guides authored
IUPUI, Team S3-G3, Harley Fall 2019 Member of IUPUI, Team S3-G3, Harley Fall 2019
IUPUI-HARLEY-F19S3G3
3 Members
24 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 23
Past 30 Days: 84
All Time: 1,291
