HP Envy m6-1105dx Keyboard Replacement
    1. HP Envy m6-1105dx Keyboard Replacement, Battery: step 1, image 1 of 1
      • Turn the computer completely off.
      • Disconnect any devices you have on it.
      • Turn the computer upside down on a flat surface.
      Ask FixBot
    2. HP Envy m6-1105dx Keyboard Replacement: step 2, image 1 of 1
      • Push the battery release latch with one hand.
      • Grab the battery with the other hand.
      • Lift out on an angle.
      Ask FixBot
    1. HP Envy m6-1105dx Keyboard Replacement, Keyboard: step 3, image 1 of 1
      • Release the screw in the center of the service cover.
      • Slide the battery release latch and pull cover towards you.
      • Lift cover off.
      Ask FixBot
    2. HP Envy m6-1105dx Keyboard Replacement: step 4, image 1 of 3 HP Envy m6-1105dx Keyboard Replacement: step 4, image 2 of 3 HP Envy m6-1105dx Keyboard Replacement: step 4, image 3 of 3
      • Remove the two JIS #0 screws that secure the keyboard to the computer.
      • Partially open the computer and rest it on its side.
      • Insert a plastic opening tool into the keyboard release holes on the inside of the battery area.
      • Press on the back of the keyboard until the keyboard disengages from the computer.
      Ask FixBot
    3. HP Envy m6-1105dx Keyboard Replacement: step 5, image 1 of 2 HP Envy m6-1105dx Keyboard Replacement: step 5, image 2 of 2
      • Return the computer to its normal position, facing you and open.
      • Lift the rear edge of the keyboard.
      • Lift the keyboard towards the front of the computer, keeping it on an angle.
      • Lift the side of the keyboard until you can access the keyboard cable and the keyboard backlight cable.
      Ask FixBot
    4. HP Envy m6-1105dx Keyboard Replacement: step 6, image 1 of 2 HP Envy m6-1105dx Keyboard Replacement: step 6, image 2 of 2
      • Release the keyboard connector cable (the wider of the two cables) by lifting the thin edge resting on top of the cable.
      • Disconnect the cable from the system board.
      • Disconnect the thinner backlight cable from the system board by pulling gently on the tab.
      Ask FixBot
    5. HP Envy m6-1105dx Keyboard Replacement: step 7, image 1 of 1
      • Remove the keyboard.
      Ask FixBot
Melody Veldorale
305 Reputation
2 Guides authored
1 Guide Comment
Unfortunately the instructions for the keyboard release inside the battery area don't really tell you which direction you should turn it. I'm afraid I'll break the plastic.
RabblerouserGT - Reply Share
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 29
All Time: 1,511
