HP Envy dv7t-7200 Service Cover Replacement
    1. HP Envy dv7t-7200 Service Cover Replacement, Battery: step 1, image 1 of 1
      • Turn the power off and disconnect all cables and cords from the laptop.
      • Place the computer on its top on a flat surface with the hinges facing away from you.
      Ask FixBot
    2. HP Envy dv7t-7200 Service Cover Replacement: step 2, image 1 of 3 HP Envy dv7t-7200 Service Cover Replacement: step 2, image 2 of 3 HP Envy dv7t-7200 Service Cover Replacement: step 2, image 3 of 3
      • Slide the battery release latch to the left which is located on the right-hand side of the battery.
      Ask FixBot
    3. HP Envy dv7t-7200 Service Cover Replacement: step 3, image 1 of 1
      • Tilt the battery away from you and lift out.
      Ask FixBot
    1. HP Envy dv7t-7200 Service Cover Replacement, Service Cover: step 4, image 1 of 1
      • Using a Phillips #01 screwdriver, remove the Phillips PM2.5Ă—5.5 screw on the service cover.
      • This screw does not come out of the service cover completely once loosened.
      Ask FixBot
    2. HP Envy dv7t-7200 Service Cover Replacement: step 5, image 1 of 2 HP Envy dv7t-7200 Service Cover Replacement: step 5, image 2 of 2
      • Slide the service cover toward the front of the laptop.
      • Lift the service cover to remove it from the laptop.
      Ask FixBot
Krystal
885 Reputation
8 Guides authored
UW Tacoma, Team S3-G3, Liner Fall 2017 Member of UW Tacoma, Team S3-G3, Liner Fall 2017
UWT-LINER-F17S3G3
5 Members
96 Guides authored
1 Guide Comment
I broke my computer. And I think it needs a new housing but I don’t know how much it costs
Elisha meyer Luwagga - Reply Share
Past 24 Hours: 4
Past 7 Days: 4
Past 30 Days: 22
All Time: 593
