HP Envy dv6-7363cl Fan Replacement
    1. HP Envy dv6-7363cl Fan Replacement, Battery: step 1, image 1 of 1
      • Flip the device upside-down so that its bottom is facing up.
      Ask FixBot
    2. HP Envy dv6-7363cl Fan Replacement: step 2, image 1 of 1
      • Push the lever underneath the battery to the left.
      Ask FixBot
    3. HP Envy dv6-7363cl Fan Replacement: step 3, image 1 of 2 HP Envy dv6-7363cl Fan Replacement: step 3, image 2 of 2
      • Lift the battery up out of its socket.
      Ask FixBot
    1. HP Envy dv6-7363cl Fan Replacement, Fan: step 4, image 1 of 1
      • Remove the circled screws from the back panel.
      Ask FixBot
    2. HP Envy dv6-7363cl Fan Replacement: step 5, image 1 of 1
      • Lift and remove the back panel of the device.
      Ask FixBot
    3. HP Envy dv6-7363cl Fan Replacement: step 6, image 1 of 3 HP Envy dv6-7363cl Fan Replacement: step 6, image 2 of 3 HP Envy dv6-7363cl Fan Replacement: step 6, image 3 of 3
      • Flip the laptop back over and carefully pry the keyboard frame out of the device.
      Ask FixBot
    4. HP Envy dv6-7363cl Fan Replacement: step 7, image 1 of 3 HP Envy dv6-7363cl Fan Replacement: step 7, image 2 of 3 HP Envy dv6-7363cl Fan Replacement: step 7, image 3 of 3
      • Lift the keyboard out of the device
      • Carefully remove ribbon cables.
      Ask FixBot
    5. HP Envy dv6-7363cl Fan Replacement: step 8, image 1 of 3 HP Envy dv6-7363cl Fan Replacement: step 8, image 2 of 3 HP Envy dv6-7363cl Fan Replacement: step 8, image 3 of 3
      • Flip device onto its back
      • Remove disk tray and circled screw.
      Ask FixBot
    6. HP Envy dv6-7363cl Fan Replacement: step 9, image 1 of 2 HP Envy dv6-7363cl Fan Replacement: step 9, image 2 of 2
      • Flip device right-side-up and remove ribbon cables from plastic cover beneath keyboard. Remove plastic cover from device.
      Ask FixBot
    7. HP Envy dv6-7363cl Fan Replacement: step 10, image 1 of 3 HP Envy dv6-7363cl Fan Replacement: step 10, image 2 of 3 HP Envy dv6-7363cl Fan Replacement: step 10, image 3 of 3
      • Disconnect red cord from DVD drive and remove DVD drive.
      Ask FixBot
    8. HP Envy dv6-7363cl Fan Replacement: step 11, image 1 of 3 HP Envy dv6-7363cl Fan Replacement: step 11, image 2 of 3 HP Envy dv6-7363cl Fan Replacement: step 11, image 3 of 3
      • Remove circled screws.
      Ask FixBot
    9. HP Envy dv6-7363cl Fan Replacement: step 12, image 1 of 2 HP Envy dv6-7363cl Fan Replacement: step 12, image 2 of 2
      • Disconnect red and white cords from blue circuit board.
      Ask FixBot
    10. HP Envy dv6-7363cl Fan Replacement: step 13, image 1 of 3 HP Envy dv6-7363cl Fan Replacement: step 13, image 2 of 3 HP Envy dv6-7363cl Fan Replacement: step 13, image 3 of 3
      • Gently pull circled pieces from their holsters.
      Ask FixBot
    11. HP Envy dv6-7363cl Fan Replacement: step 14, image 1 of 2 HP Envy dv6-7363cl Fan Replacement: step 14, image 2 of 2
      • Turn device onto its back and remove circled screws from Wi-Fi card.
      • Flip device back over and unscrew disk reader
      Ask FixBot
    12. HP Envy dv6-7363cl Fan Replacement: step 15, image 1 of 1
      • Remove circled screws from blue circuit board and lift fan assembly out of device.
      Ask FixBot
dylananthony
564 Reputation
3 Guides authored
2 Guide Comments
My laptop is a slightly different model and everything provided by the author is likely accurate for their model. I only mention this to caution that your repair may be slightly different depending on your specific model. Mine was different in a few areas though held mostly true with my dv6t-7000. Cheers!
zabadoo - Reply Share
Salom menga shu modeldagi kompyuterni ustgi qopqogʻini topib pochta qila olasizmi iloji boʻlsa iltimos nomerim +998991768069 shu nomerga telfon qib bogʻlanishiz mumkin men bilan
Shamsullo Quzratov - Reply Share
Past 24 Hours: 3
Past 7 Days: 13
Past 30 Days: 58
All Time: 5,199
