HP Envy Ultrabook 4-1015dx Screen Replacement
    1. HP Envy Ultrabook 4-1015dx Screen Replacement, Battery: step 1, image 1 of 1
      • Make sure that the device is turned off and that all external devices are removed.
      Ask FixBot
    2. HP Envy Ultrabook 4-1015dx Screen Replacement: step 2, image 1 of 1
      • Flip the device over so that the back plate is facing upwards.
      Ask FixBot
    3. HP Envy Ultrabook 4-1015dx Screen Replacement: step 3, image 1 of 2 HP Envy Ultrabook 4-1015dx Screen Replacement: step 3, image 2 of 2
      • Using a small (size 0) Phillips head screwdriver, remove the twelve 5.5 mm external Phillips head screws that connect the back plate to the device.
      • Make sure to set the screws aside in a safe place so that you do not lose them, as they will be needed to reattach the backplate later.
      Ask FixBot
    4. HP Envy Ultrabook 4-1015dx Screen Replacement: step 4, image 1 of 2 HP Envy Ultrabook 4-1015dx Screen Replacement: step 4, image 2 of 2
      • Using the plastic opening tool, gently pry off the back plate from the device.
      Ask FixBot
    5. HP Envy Ultrabook 4-1015dx Screen Replacement: step 5, image 1 of 2 HP Envy Ultrabook 4-1015dx Screen Replacement: step 5, image 2 of 2
      • The large black box with the white warning images is the battery.
      • Move the ribbon cable so that it is no longer on top of the battery.
      Ask FixBot
    6. HP Envy Ultrabook 4-1015dx Screen Replacement: step 6, image 1 of 2 HP Envy Ultrabook 4-1015dx Screen Replacement: step 6, image 2 of 2
      • Using a small (size 0) Phillips head screwdriver, remove the three 3.5 mm Phillips head internal screws that hold the battery in place.
      • Make sure not to lose these internal screws; they will later be used to reattach the battery.
      Ask FixBot
    7. HP Envy Ultrabook 4-1015dx Screen Replacement: step 7, image 1 of 2 HP Envy Ultrabook 4-1015dx Screen Replacement: step 7, image 2 of 2
      • Lift up the battery and remove it from the slot as shown.
      Ask FixBot
    8. HP Envy Ultrabook 4-1015dx Screen Replacement: step 8, image 1 of 3 HP Envy Ultrabook 4-1015dx Screen Replacement: step 8, image 2 of 3 HP Envy Ultrabook 4-1015dx Screen Replacement: step 8, image 3 of 3
      • Use the plastic opening tool to disconnect the battery cable.
      Ask FixBot
    9. HP Envy Ultrabook 4-1015dx Screen Replacement: step 9, image 1 of 1
      • Lift up the battery and remove it from the device.
      Ask FixBot
    1. HP Envy Ultrabook 4-1015dx Screen Replacement, Hard Disk Drive: step 10, image 1 of 3 HP Envy Ultrabook 4-1015dx Screen Replacement, Hard Disk Drive: step 10, image 2 of 3 HP Envy Ultrabook 4-1015dx Screen Replacement, Hard Disk Drive: step 10, image 3 of 3
      • The hard disk drive is under a metallic looking case in the bottom-right corner of the device.
      • Using a size 0 Phillips head screwdriver, remove the four 3 mm size 0 screws attaching the hard drive casing to the device.
      Ask FixBot
    2. HP Envy Ultrabook 4-1015dx Screen Replacement: step 11, image 1 of 1
      • Remove the hard drive case.
      Ask FixBot
    3. HP Envy Ultrabook 4-1015dx Screen Replacement: step 12, image 1 of 1
      • Unplug the hard drive from the hard drive plug.
      Ask FixBot
    1. HP Envy Ultrabook 4-1015dx Screen Replacement, Keyboard: step 13, image 1 of 2 HP Envy Ultrabook 4-1015dx Screen Replacement, Keyboard: step 13, image 2 of 2
      • After removing the hard drive, you now must remove the motherboard. Start by pulling out the ribbon cable that attaches the touch pad to the motherboard.
      Ask FixBot
    2. HP Envy Ultrabook 4-1015dx Screen Replacement: step 14, image 1 of 2 HP Envy Ultrabook 4-1015dx Screen Replacement: step 14, image 2 of 2
      • Using the plastic opening tool, pry out the small chip next to the touch pad that is attached via ribbon cable to the motherboard. Make sure to pry from the side that only has one small black bump, rather than the side that has two.
      • The chip should be located underneath the ribbon cables, which is reflected in the first image.
      Ask FixBot
    3. HP Envy Ultrabook 4-1015dx Screen Replacement: step 15, image 1 of 2 HP Envy Ultrabook 4-1015dx Screen Replacement: step 15, image 2 of 2
      • Using the plastic opening tool, flip up the clasp for the ribbon cable connecting the keyboard to the motherboard and then unplug the ribbon cable.
      Ask FixBot
    4. HP Envy Ultrabook 4-1015dx Screen Replacement: step 16, image 1 of 2 HP Envy Ultrabook 4-1015dx Screen Replacement: step 16, image 2 of 2
      • Using the plastic spudger, disconnect the hard drive plug from the motherboard.
      Ask FixBot
    5. HP Envy Ultrabook 4-1015dx Screen Replacement: step 17, image 1 of 1
      • Now, remove the LAN adapter. Peel back the black plastic cover so that the LAN adapter is visible.
      Ask FixBot
    6. HP Envy Ultrabook 4-1015dx Screen Replacement: step 18, image 1 of 2 HP Envy Ultrabook 4-1015dx Screen Replacement: step 18, image 2 of 2
      • Pull off the two cables from the LAN adapter.
      Ask FixBot
    7. HP Envy Ultrabook 4-1015dx Screen Replacement: step 19, image 1 of 3 HP Envy Ultrabook 4-1015dx Screen Replacement: step 19, image 2 of 3 HP Envy Ultrabook 4-1015dx Screen Replacement: step 19, image 3 of 3
      • Using a size 0 Phillips head screwdriver, remove the two metallic 3 mm Phillips head screws.
      • Once the screws are removed, the LAN adapter should pop up. Pull out the LAN adapter from its socket.
      Ask FixBot
    8. HP Envy Ultrabook 4-1015dx Screen Replacement: step 20, image 1 of 2 HP Envy Ultrabook 4-1015dx Screen Replacement: step 20, image 2 of 2
      • Use plastic spudger to remove black and red wire from the socket.
      Ask FixBot
    9. HP Envy Ultrabook 4-1015dx Screen Replacement: step 21, image 1 of 2 HP Envy Ultrabook 4-1015dx Screen Replacement: step 21, image 2 of 2
      • Using plastic spudger, disconnect power connector.
      Ask FixBot
    10. HP Envy Ultrabook 4-1015dx Screen Replacement: step 22, image 1 of 1
      • Disconnect display panel cable by pulling on black tab to unplug the cable from the socket
      Ask FixBot
    11. HP Envy Ultrabook 4-1015dx Screen Replacement: step 23, image 1 of 1
      • Using the plastic opening tool, flip up the clasp on the power button cable and unplug the power button cable from the socket.
      Ask FixBot
    12. HP Envy Ultrabook 4-1015dx Screen Replacement: step 24, image 1 of 3 HP Envy Ultrabook 4-1015dx Screen Replacement: step 24, image 2 of 3 HP Envy Ultrabook 4-1015dx Screen Replacement: step 24, image 3 of 3
      • Remove clasp beneath the headphone port.
      • Using a size 0 Phillips head screwdriver, remove the 3 mm size 0 Phillips head screw that attaches the clasp to the device.
      • Then, take off the clasp.
      Ask FixBot
    13. HP Envy Ultrabook 4-1015dx Screen Replacement: step 25, image 1 of 2 HP Envy Ultrabook 4-1015dx Screen Replacement: step 25, image 2 of 2
      • Using a size 0 Phillips head screwdriver, remove the two 3 mm size 0 screws attaching the motherboard to the device.
      Ask FixBot
    14. HP Envy Ultrabook 4-1015dx Screen Replacement: step 26, image 1 of 2 HP Envy Ultrabook 4-1015dx Screen Replacement: step 26, image 2 of 2
      • Remove the fan.
      • Use a size 0 Phillips head screwdriver to remove the 3 mm size 0 screw attaching the fan to the device.
      • Pull the fan out of the slot and, using the plastic opening tool, unplug the connector cable from the socket.
      Ask FixBot
    15. HP Envy Ultrabook 4-1015dx Screen Replacement: step 27, image 1 of 1
      • Unplug the cable attaching the keyboard to the motherboard.
      Ask FixBot
    16. HP Envy Ultrabook 4-1015dx Screen Replacement: step 28, image 1 of 2 HP Envy Ultrabook 4-1015dx Screen Replacement: step 28, image 2 of 2
      • Remove the subwoofer.
      • Using plastic opening tool, remove the red and black subwoofer cable.
      • Use a size 0 Phillips head screwdriver to remove the two 3 mm size 0 screws attaching the subwoofer to the device.
      Ask FixBot
    17. HP Envy Ultrabook 4-1015dx Screen Replacement: step 29, image 1 of 2 HP Envy Ultrabook 4-1015dx Screen Replacement: step 29, image 2 of 2
      • Use a size 0 Phillips head screwdriver to remove the 3 mm size 0 screw attaching the charging port clasp to the device.
      • Remove the charging port clasp.
      Ask FixBot
    18. HP Envy Ultrabook 4-1015dx Screen Replacement: step 30, image 1 of 2 HP Envy Ultrabook 4-1015dx Screen Replacement: step 30, image 2 of 2
      • Use a size 0 Phillips head screwdriver to remove the 3 mm size 0 screw attaching the black claspto the device.
      • Remove the black clasp.
      Ask FixBot
    19. HP Envy Ultrabook 4-1015dx Screen Replacement: step 31, image 1 of 1
      • Lift up the motherboard and the power cable off of the device and place them to the side.
      Ask FixBot
    20. HP Envy Ultrabook 4-1015dx Screen Replacement: step 32, image 1 of 3 HP Envy Ultrabook 4-1015dx Screen Replacement: step 32, image 2 of 3 HP Envy Ultrabook 4-1015dx Screen Replacement: step 32, image 3 of 3
      • Use a size 0 Phillips head screwdriver to remove the four 3 mm size 0 screws securing the hinges to the device.
      • Lift up the hinges off of the keyboard.
      Ask FixBot
    21. HP Envy Ultrabook 4-1015dx Screen Replacement: step 33, image 1 of 2 HP Envy Ultrabook 4-1015dx Screen Replacement: step 33, image 2 of 2
      • Using a size 0 Phillips head screwdriver, remove all of the 3 mm size 0 screws attaching the keyboard to the device.
      Ask FixBot
    22. HP Envy Ultrabook 4-1015dx Screen Replacement: step 34, image 1 of 1
      • Lift up and remove the keyboard from the device.
      Ask FixBot
    1. HP Envy Ultrabook 4-1015dx Screen Replacement, Screen: step 35, image 1 of 3 HP Envy Ultrabook 4-1015dx Screen Replacement, Screen: step 35, image 2 of 3 HP Envy Ultrabook 4-1015dx Screen Replacement, Screen: step 35, image 3 of 3
      • On the bottom corners of the screen are two plastic covers. Pry these off using the plastic spudger
      • Remove the two 3 mm size 0 Phillips screws on the left and right.
      Ask FixBot
    2. HP Envy Ultrabook 4-1015dx Screen Replacement: step 36, image 1 of 2 HP Envy Ultrabook 4-1015dx Screen Replacement: step 36, image 2 of 2
      • Pry open the plastic bezel around the screen using the plastic opening tool.
      • There is two sided tape that holds the bezel on.
      Ask FixBot
    3. HP Envy Ultrabook 4-1015dx Screen Replacement: step 37, image 1 of 2 HP Envy Ultrabook 4-1015dx Screen Replacement: step 37, image 2 of 2
      • Remove the four 4.0 mm Phillips screws located at each corner of the screen using a Phillips #1 screwdriver.
      Ask FixBot
    4. HP Envy Ultrabook 4-1015dx Screen Replacement: step 38, image 1 of 1
      • Remove the screen by pulling the metal tab at the top.
      Ask FixBot
    5. HP Envy Ultrabook 4-1015dx Screen Replacement: step 39, image 1 of 2 HP Envy Ultrabook 4-1015dx Screen Replacement: step 39, image 2 of 2
      • Disconnect the forty pin display connector located on thee backside of the bottom of the screen.
      Ask FixBot
    6. HP Envy Ultrabook 4-1015dx Screen Replacement: step 40, image 1 of 1
      • Remove the screen from the socket.
      Ask FixBot
Finish Line
2 other people completed this guide.
Zachary Kelley
160 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 24
All Time: 554
