HP Envy Ultrabook 4-1015dx Bluetooth Module Replacement
    1. HP Envy Ultrabook 4-1015dx Bluetooth Module Replacement, Battery: step 1, image 1 of 1
      • Make sure that the device is turned off and that all external devices are removed.
      Ask FixBot
    2. HP Envy Ultrabook 4-1015dx Bluetooth Module Replacement: step 2, image 1 of 1
      • Flip the device over so that the back plate is facing upwards.
      Ask FixBot
    3. HP Envy Ultrabook 4-1015dx Bluetooth Module Replacement: step 3, image 1 of 2 HP Envy Ultrabook 4-1015dx Bluetooth Module Replacement: step 3, image 2 of 2
      • Using a small (size 0) Phillips head screwdriver, remove the twelve 5.5 mm external Phillips head screws that connect the back plate to the device.
      • Make sure to set the screws aside in a safe place so that you do not lose them, as they will be needed to reattach the backplate later.
      Ask FixBot
    4. HP Envy Ultrabook 4-1015dx Bluetooth Module Replacement: step 4, image 1 of 2 HP Envy Ultrabook 4-1015dx Bluetooth Module Replacement: step 4, image 2 of 2
      • Using the plastic opening tool, gently pry off the back plate from the device.
      Ask FixBot
    5. HP Envy Ultrabook 4-1015dx Bluetooth Module Replacement: step 5, image 1 of 2 HP Envy Ultrabook 4-1015dx Bluetooth Module Replacement: step 5, image 2 of 2
      • The large black box with the white warning images is the battery.
      • Move the ribbon cable so that it is no longer on top of the battery.
      Ask FixBot
    6. HP Envy Ultrabook 4-1015dx Bluetooth Module Replacement: step 6, image 1 of 2 HP Envy Ultrabook 4-1015dx Bluetooth Module Replacement: step 6, image 2 of 2
      • Using a small (size 0) Phillips head screwdriver, remove the three 3.5 mm Phillips head internal screws that hold the battery in place.
      • Make sure not to lose these internal screws; they will later be used to reattach the battery.
      Ask FixBot
    7. HP Envy Ultrabook 4-1015dx Bluetooth Module Replacement: step 7, image 1 of 2 HP Envy Ultrabook 4-1015dx Bluetooth Module Replacement: step 7, image 2 of 2
      • Lift up the battery and remove it from the slot as shown.
      Ask FixBot
    8. HP Envy Ultrabook 4-1015dx Bluetooth Module Replacement: step 8, image 1 of 3 HP Envy Ultrabook 4-1015dx Bluetooth Module Replacement: step 8, image 2 of 3 HP Envy Ultrabook 4-1015dx Bluetooth Module Replacement: step 8, image 3 of 3
      • Use the plastic opening tool to disconnect the battery cable.
      Ask FixBot
    9. HP Envy Ultrabook 4-1015dx Bluetooth Module Replacement: step 9, image 1 of 1
      • Lift up the battery and remove it from the device.
      Ask FixBot
    1. HP Envy Ultrabook 4-1015dx Bluetooth Module Replacement, Bluetooth Module: step 10, image 1 of 2 HP Envy Ultrabook 4-1015dx Bluetooth Module Replacement, Bluetooth Module: step 10, image 2 of 2
      • Remove the tape holding the power connector cable and loosen the cable from the routing channel to gain access to the bluetooth module.
      Ask FixBot
    2. HP Envy Ultrabook 4-1015dx Bluetooth Module Replacement: step 11, image 1 of 1
      Tool used on this step:
      Buy
      • Use a pair of small needle nose pliers or tweezers to disconnect the antenna of the bluetooth module.
      Ask FixBot
    3. HP Envy Ultrabook 4-1015dx Bluetooth Module Replacement: step 12, image 1 of 1
      • Using a #0 Phillips head screwdriver, remove the two 3 mm size 0 screws securing the Bluetooth module in place.
      Ask FixBot
    4. HP Envy Ultrabook 4-1015dx Bluetooth Module Replacement: step 13, image 1 of 2 HP Envy Ultrabook 4-1015dx Bluetooth Module Replacement: step 13, image 2 of 2
      • Grasp the bluetooth module by its sides and remove it from the computer by wiggling gently. Then place the bluetooth module in an anti-static bag.
      Ask FixBot
Michael Horton
130 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 62
All Time: 773
