Introduction
The keyboard is a frequently used components on any laptop, and over time, it can fail due to debris buildup, electrical faults, or physical damage. If your HP Envy TouchSmart m7-k010dx laptop’s keyboard has stopped responding, certain keys no longer work, or you’ve experienced liquid damage or excessive wear, a keyboard replacement may be necessary.
This guide will take you step-by-step through the keyboard replacement process for the HP Envy TouchSmart m7-k010dx. While the task requires careful handling and some disassembly of the laptop’s casing, it’s a great way to restore full functionality and extend your computer’s lifespan. With the right tools and a bit of patience, you can replace the faulty keyboard and have your HP Envy working like new again.
Turn your computer over so that the bottom is facing up.
Slide the left black switch towards center.
You should see an unlock image exposed to the left of switch if done correctly.
With the computer turned over use a nylon spudger to pry the rectangular pads off to reveal two hidden screws.
Using a Phillips #0 screwdriver, remove the screw that is beneath the black rubber pad, as well as the other holding down the black corner plastic pieces on both the left and right sides.
Using a JIS #00 screwdriver, remove the two screws that were revealed when the optical drive was removed.
Use a Phillips #0 screwdriver to remove all screws that are visible on the bottom.
There is an oval tab near the center of the laptop, use the flat end of a nylon spudger to wedge it free to reveal another Phillips #0 screw.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
