HP Envy TouchSmart 4-1215dx Display Replacement
    1. HP Envy TouchSmart 4-1215dx Display Replacement, Display: step 1, image 1 of 1
      • Remove both 3 mm screws at the bottom of the display using a Phillips #0 screwdriver.
      Ask FixBot
    2. HP Envy TouchSmart 4-1215dx Display Replacement: step 2, image 1 of 2 HP Envy TouchSmart 4-1215dx Display Replacement: step 2, image 2 of 2
      • Using an iFixit opening tool, pry the screen from the back panel.
      • Remove the back panel.
      Ask FixBot
    3. HP Envy TouchSmart 4-1215dx Display Replacement: step 3, image 1 of 1
      • Close the laptop so the front is facing you.
      • Remove the four 3 mm screws from the two brackets at the front using a Phillips #0 screwdriver.
      • Remove the brackets.
      Ask FixBot
    4. HP Envy TouchSmart 4-1215dx Display Replacement: step 4, image 1 of 3 HP Envy TouchSmart 4-1215dx Display Replacement: step 4, image 2 of 3 HP Envy TouchSmart 4-1215dx Display Replacement: step 4, image 3 of 3
      • Remove the 3 mm screws from the back brackets using a Phillips #0 screwdriver.
      • Remove the 1 mm screws with a Phillips #00 screwdriver.
      • Lift up the display until the brackets are sticking straight up.
      Ask FixBot
    5. HP Envy TouchSmart 4-1215dx Display Replacement: step 5, image 1 of 1
      • Peel off the aluminum tape located at the top of the display.
      Ask FixBot
    6. HP Envy TouchSmart 4-1215dx Display Replacement: step 6, image 1 of 2 HP Envy TouchSmart 4-1215dx Display Replacement: step 6, image 2 of 2
      • Disconnect the ribbon cable and peel off the connected tape from the display.
      Ask FixBot
    7. HP Envy TouchSmart 4-1215dx Display Replacement: step 7, image 1 of 2 HP Envy TouchSmart 4-1215dx Display Replacement: step 7, image 2 of 2
      • Lift the display up separately from the screen.
      • Peel off the orange tape at the bottom of the display connecting to the laptop.
      Ask FixBot
    8. HP Envy TouchSmart 4-1215dx Display Replacement: step 8, image 1 of 1
      • Lift up the display.
      • If your display is cracked or shattered, you should tape up the effected parts in order to avoid injury.
      Ask FixBot
Isaac York
157 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 31
All Time: 549
