HP Envy TouchSmart 15 Solid State Drive Replacement
Views: 3.6K
View statistics:
Past 24 Hours:
2
Past 7 Days:
23
Past 30 Days:
101
All Time:
3,597
Comments: 2
2 guide comments.
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 3 - 7 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
You should replace your solid state drive if it has become damaged or corrupted. The OS will not boot properly is a major system of this.
Tools
    1. HP Envy TouchSmart 15 Solid State Drive Replacement, Battery: step 1, image 1 of 1
      • Press the battery release tab and the battery will pop up.
      Ask FixBot
    2. HP Envy TouchSmart 15 Solid State Drive Replacement: step 2, image 1 of 1
      • Remove the battery from the laptop, it will come out easily.
      Ask FixBot
    1. HP Envy TouchSmart 15 Solid State Drive Replacement, Accessory Plate: step 3, image 1 of 2 HP Envy TouchSmart 15 Solid State Drive Replacement, Accessory Plate: step 3, image 2 of 2
      • Remove the single screw holding the accessory plate. This is a PH0 2.0x2.5 screw.
      Ask FixBot
    2. HP Envy TouchSmart 15 Solid State Drive Replacement: step 4, image 1 of 3 HP Envy TouchSmart 15 Solid State Drive Replacement: step 4, image 2 of 3 HP Envy TouchSmart 15 Solid State Drive Replacement: step 4, image 3 of 3
      • Pry the accessory plate up from the back of the laptop by applying force upwards where the screw was removed.
      Ask FixBot
    1. HP Envy TouchSmart 15 Solid State Drive Replacement, Solid State Drive: step 5, image 1 of 2 HP Envy TouchSmart 15 Solid State Drive Replacement, Solid State Drive: step 5, image 2 of 2
      • Remove the PM 2.0x2.5 screw with the PH#0 Screwdriver attachment that is shown at the corner of the Solid State Drive.
      • After you have removed the screw, the Solid State Drive should lift up.
      Ask FixBot
    2. HP Envy TouchSmart 15 Solid State Drive Replacement: step 6, image 1 of 2 HP Envy TouchSmart 15 Solid State Drive Replacement: step 6, image 2 of 2
      • Very carefully, remove the SSD by gently pulling away from the SSD socket.
      Ask FixBot
4 other people completed this guide.
Ramon Villadonga
1,042 Reputation
5 Guides authored
USF Tampa, Team 2-6, Sullivan Fall 2015 Member of USF Tampa, Team 2-6, Sullivan Fall 2015
USFT-SULLIVAN-F15S2G6
4 Members
120 Guides authored
2 Guide Comments
Please what type of ssd is that and can i get the specifications? I want to get one for my laptop since it didn’t ship with it. Its the same as the one above. HP ENVY TS 15 Notebook PC Thanks.
temidayoabayomizannu - Reply Share
Wht type of ssd i can insert here
Plz help me
Kavindra Danushka Rajapaksha - Reply Share
Past 24 Hours: 2
Past 7 Days: 23
Past 30 Days: 101
All Time: 3,597
