HP Envy TouchSmart 15 RAM Replacement
    1. HP Envy TouchSmart 15 RAM Replacement, Battery: step 1, image 1 of 1
      • Press the battery release tab and the battery will pop up.
      Ask FixBot
    2. HP Envy TouchSmart 15 RAM Replacement: step 2, image 1 of 1
      • Remove the battery from the laptop, it will come out easily.
      Ask FixBot
    1. HP Envy TouchSmart 15 RAM Replacement, Accessory Plate: step 3, image 1 of 2 HP Envy TouchSmart 15 RAM Replacement, Accessory Plate: step 3, image 2 of 2
      • Remove the single screw holding the accessory plate. This is a PH0 2.0x2.5 screw.
      Ask FixBot
    2. HP Envy TouchSmart 15 RAM Replacement: step 4, image 1 of 3 HP Envy TouchSmart 15 RAM Replacement: step 4, image 2 of 3 HP Envy TouchSmart 15 RAM Replacement: step 4, image 3 of 3
      • Pry the accessory plate up from the back of the laptop by applying force upwards where the screw was removed.
      Ask FixBot
    1. HP Envy TouchSmart 15 RAM Replacement, RAM: step 5, image 1 of 2 HP Envy TouchSmart 15 RAM Replacement, RAM: step 5, image 2 of 2
      • Hold back the covering to reveal the RAM modules.
      Ask FixBot
    2. HP Envy TouchSmart 15 RAM Replacement: step 6, image 1 of 1
      • Press the clips on the edges of the RAM modules outward to pop them out.
      Ask FixBot
    3. HP Envy TouchSmart 15 RAM Replacement: step 7, image 1 of 3 HP Envy TouchSmart 15 RAM Replacement: step 7, image 2 of 3 HP Envy TouchSmart 15 RAM Replacement: step 7, image 3 of 3
      • You can now remove the RAM modules you need to replace. You can replace the top one, the bottom one, or both if needed.
      Ask FixBot
3 other people completed this guide.
Robert Patterson
1,494 Reputation
5 Guides authored
USF Tampa, Team 2-6, Sullivan Fall 2015 Member of USF Tampa, Team 2-6, Sullivan Fall 2015
USFT-SULLIVAN-F15S2G6
4 Members
120 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 23
Past 30 Days: 97
All Time: 2,103
