HP Envy TouchSmart 15 Fan Replacement
    1. HP Envy TouchSmart 15 Fan  Replacement, Battery: step 1, image 1 of 1
      • Press the battery release tab and the battery will pop up.
      Ask FixBot
    2. HP Envy TouchSmart 15 Fan  Replacement: step 2, image 1 of 1
      • Remove the battery from the laptop, it will come out easily.
      Ask FixBot
    1. HP Envy TouchSmart 15 Fan  Replacement, Accessory Plate: step 3, image 1 of 2 HP Envy TouchSmart 15 Fan  Replacement, Accessory Plate: step 3, image 2 of 2
      • Remove the single screw holding the accessory plate. This is a PH0 2.0x2.5 screw.
      Ask FixBot
    2. HP Envy TouchSmart 15 Fan  Replacement: step 4, image 1 of 3 HP Envy TouchSmart 15 Fan  Replacement: step 4, image 2 of 3 HP Envy TouchSmart 15 Fan  Replacement: step 4, image 3 of 3
      • Pry the accessory plate up from the back of the laptop by applying force upwards where the screw was removed.
      Ask FixBot
    1. HP Envy TouchSmart 15 Fan  Replacement, Solid State Drive: step 5, image 1 of 2 HP Envy TouchSmart 15 Fan  Replacement, Solid State Drive: step 5, image 2 of 2
      • Remove the PM 2.0x2.5 screw with the PH#0 Screwdriver attachment that is shown at the corner of the Solid State Drive.
      • After you have removed the screw, the Solid State Drive should lift up.
      Ask FixBot
    2. HP Envy TouchSmart 15 Fan  Replacement: step 6, image 1 of 2 HP Envy TouchSmart 15 Fan  Replacement: step 6, image 2 of 2
      • Very carefully, remove the SSD by gently pulling away from the SSD socket.
      Ask FixBot
    1. HP Envy TouchSmart 15 Fan  Replacement, Hard Drive: step 7, image 1 of 2 HP Envy TouchSmart 15 Fan  Replacement, Hard Drive: step 7, image 2 of 2
      • Use the plastic opening tool to pry the hard drive away from the board. Notice that there is a slit centered at the back of where the hard drive is sitting. This is where you'll insert the plastic opening tool as shown in the photo. Finally, pry with the plastic opening tool to remove the hard drive.
      Ask FixBot
    2. HP Envy TouchSmart 15 Fan  Replacement: step 8, image 1 of 2 HP Envy TouchSmart 15 Fan  Replacement: step 8, image 2 of 2
      • Firmly grasp the connector's base as shown and pull to remove from the hard drive.
      Ask FixBot
    1. HP Envy TouchSmart 15 Fan  Replacement, Back Plate: step 9, image 1 of 3 HP Envy TouchSmart 15 Fan  Replacement, Back Plate: step 9, image 2 of 3 HP Envy TouchSmart 15 Fan  Replacement, Back Plate: step 9, image 3 of 3
      • Remove the highlighted rubber stoppers with a metal spudger as pictured. They should expose a screw that you will need to remove in a later step.
      Ask FixBot
    2. HP Envy TouchSmart 15 Fan  Replacement: step 10, image 1 of 3 HP Envy TouchSmart 15 Fan  Replacement: step 10, image 2 of 3 HP Envy TouchSmart 15 Fan  Replacement: step 10, image 3 of 3
      • Remove plastic cover highlighted. It should expose a screw that you will need in a later step.
      Ask FixBot
    3. HP Envy TouchSmart 15 Fan  Replacement: step 11, image 1 of 1
      • Remove all highlighted screws with PH 1 screwdriver. These screws are PM 2.0x2.5.
      Ask FixBot
    4. HP Envy TouchSmart 15 Fan  Replacement: step 12, image 1 of 2 HP Envy TouchSmart 15 Fan  Replacement: step 12, image 2 of 2
      • Remove all highlighted screws from the battery access area. These are PM 1.5x2.0 screws
      Ask FixBot
    5. HP Envy TouchSmart 15 Fan  Replacement: step 13, image 1 of 1
      • Remove screws highlighted with PH1 screwdriver from accessory plate area.These are PM 2.5x3.0 screws
      • Remove screws highlighted with PH1 screwdriver from accessory plate area. These are PM 2.5x4.5 screws
      Ask FixBot
    6. HP Envy TouchSmart 15 Fan  Replacement: step 14, image 1 of 3 HP Envy TouchSmart 15 Fan  Replacement: step 14, image 2 of 3 HP Envy TouchSmart 15 Fan  Replacement: step 14, image 3 of 3
      • Pry open back plate area with plastic opening tool. The back plate should pry open with relative ease. If you feel some resistance at any point please refer to steps 2-5 because a screw has probably been missed.
      Ask FixBot
    1. HP Envy TouchSmart 15 Fan  Replacement, Fan: step 15, image 1 of 2 HP Envy TouchSmart 15 Fan  Replacement, Fan: step 15, image 2 of 2
      • There are 3 screws holding the fan in place. These are PM 2.5x4.5 screws
      Ask FixBot
    2. HP Envy TouchSmart 15 Fan  Replacement: step 16, image 1 of 2 HP Envy TouchSmart 15 Fan  Replacement: step 16, image 2 of 2
      • There are 3 strips of tape. Remove them with your hand.
      Ask FixBot
    3. HP Envy TouchSmart 15 Fan  Replacement: step 17, image 1 of 1
      • Remove the fan by sliding it out and pulling it upwards. Set the fan off to the side to reveal the connector.
      Ask FixBot
    4. HP Envy TouchSmart 15 Fan  Replacement: step 18, image 1 of 2 HP Envy TouchSmart 15 Fan  Replacement: step 18, image 2 of 2
      • Remove the black connector from the white insert shown at the center of the picture just below the fingers pinching the black connector.
      • The connector will come out straight up.
      Ask FixBot
21 other people completed this guide.
Ramon Villadonga
1,042 Reputation
5 Guides authored
USF Tampa, Team 2-6, Sullivan Fall 2015 Member of USF Tampa, Team 2-6, Sullivan Fall 2015
USFT-SULLIVAN-F15S2G6
4 Members
120 Guides authored
13 Guide Comments
TY. excellent write up =)
Rameez Aftab - Reply Share
TY good write up I did not have an SSD drive . Some of the screw locations were slightly different [I suppose they very by configuration].
I meticulously followed your instructions. I did have trouble reconnecting the hard drive but it was my lack of experience and a good magnifying glass. Problem fixed. Fan working great.
Really appreciate your photos and explanation
jkbushtx - Reply Share
Excellent directions. Great pictures. Everything was as specified in the instructions. Original fan had a piece of broken plastic in it Removed and reassembled, works great. Make sure flat lead for hard drive is correctly installed.
fischer.jim59 - Reply Share
This was seriously better than any YouTube video ever. It worked like a charm period thank you so much.
Ginger Grant - Reply Share
Excellent walk thru... best I've ever seen!
Julie Baker - Reply Share
Past 24 Hours: 6
Past 7 Days: 28
Past 30 Days: 118
All Time: 14,895
