HP Envy TouchSmart 15 Digitizer Replacement
    1. HP Envy TouchSmart 15 Digitizer Replacement, Touch Screen/Digitizer: step 1, image 1 of 1
      • Lay the laptop down with the bottom facing up.
      Ask FixBot
    2. HP Envy TouchSmart 15 Digitizer Replacement: step 2, image 1 of 1
      • Slide the switch to release the battery and remove it.
      Ask FixBot
    3. HP Envy TouchSmart 15 Digitizer Replacement: step 3, image 1 of 2 HP Envy TouchSmart 15 Digitizer Replacement: step 3, image 2 of 2
      • Remove the screw from the access panel. Gently lift and remove the panel.
      Ask FixBot
    4. HP Envy TouchSmart 15 Digitizer Replacement: step 4, image 1 of 3 HP Envy TouchSmart 15 Digitizer Replacement: step 4, image 2 of 3 HP Envy TouchSmart 15 Digitizer Replacement: step 4, image 3 of 3
      • Remove the hard drive and disconnect its ribbon cable from both the hard drive and the motherboard.
      Ask FixBot
    5. HP Envy TouchSmart 15 Digitizer Replacement: step 5, image 1 of 3 HP Envy TouchSmart 15 Digitizer Replacement: step 5, image 2 of 3 HP Envy TouchSmart 15 Digitizer Replacement: step 5, image 3 of 3
      • Remove the screws to loosen the bottom casing.
      • Remove the two feet to reveal the screws underneath.
      Ask FixBot
    6. HP Envy TouchSmart 15 Digitizer Replacement: step 6, image 1 of 1
      • Gently pry the edges to loosen the case.
      • Once loose, lift and remove the plastic casing to reveal the motherboard.
      Ask FixBot
    7. HP Envy TouchSmart 15 Digitizer Replacement: step 7, image 1 of 2 HP Envy TouchSmart 15 Digitizer Replacement: step 7, image 2 of 2
      • Lift and detach the wireless antenna cables.
      • Lift and de-route the wires from their tracks until you reach the display hinges.
      Ask FixBot
    8. HP Envy TouchSmart 15 Digitizer Replacement: step 8, image 1 of 1
      • Detach the two cables. Lift the tab for the ribbon cable before pulling it out.
      Ask FixBot
    9. HP Envy TouchSmart 15 Digitizer Replacement: step 9, image 1 of 2 HP Envy TouchSmart 15 Digitizer Replacement: step 9, image 2 of 2
      • Remove the screws from each hinge.
      • Lift the hinges with pliers until they are perpendicular to the case.
      • Lift and remove the bottom of the laptop from the screen.
      Ask FixBot
    10. HP Envy TouchSmart 15 Digitizer Replacement: step 10, image 1 of 1
      • Lift the tabs in both the bottom corners and remove the screws beneath.
      Ask FixBot
    11. HP Envy TouchSmart 15 Digitizer Replacement: step 11, image 1 of 2 HP Envy TouchSmart 15 Digitizer Replacement: step 11, image 2 of 2
      • Using a pry tool as necessary, remove the digitizer from the rest of the screen panel. Be careful around the top edge as there are delicate components beneath.
      Ask FixBot
    12. HP Envy TouchSmart 15 Digitizer Replacement: step 12, image 1 of 3 HP Envy TouchSmart 15 Digitizer Replacement: step 12, image 2 of 3 HP Envy TouchSmart 15 Digitizer Replacement: step 12, image 3 of 3
      • Using a heat gun, carefully loosen the adhesive connecting the digitizer to its plastic border.
      • Gently peel the digitizer away from the plastic border.
      • When installing the new one digitizer, press firmly around the edges.
      Ask FixBot
5 other people completed this guide.
Micah Kempf
260 Reputation
1 Guide authored
4 Guide Comments
These directions are perfect. I was able to successfully change my digitizer in under an hour
Joe Russo - Reply Share
where do you get the digitizer?
Jacob - Reply Share
Amazing,
My name is Nevelson, I have exactly same laptop and mine also is broke, but I don't know where to get the replacement; only the sensor, please I need help and willing to pay handsomely.
Nevelson Odimgbe - Reply Share
Nevelson, I have updated this page to included a link to the part on amazon.
Micah Kempf - Reply Share
Past 24 Hours: 3
Past 7 Days: 30
Past 30 Days: 124
All Time: 15,112
