HP Envy M6-1205DX RAM Replacement
    1. HP Envy M6-1205DX RAM Replacement, Battery: step 1, image 1 of 1
      • Lay the device face down to begin.
      Ask FixBot
    2. HP Envy M6-1205DX RAM Replacement: step 2, image 1 of 1
      • Slide the release mechanism to the left to release the battery.
      Ask FixBot
    3. HP Envy M6-1205DX RAM Replacement: step 3, image 1 of 2 HP Envy M6-1205DX RAM Replacement: step 3, image 2 of 2
      • Remove the battery.
      Ask FixBot
    1. HP Envy M6-1205DX RAM Replacement, Back Panel: step 4, image 1 of 1
      • Using a Phillips #1 screwdriver, remove the 8.6 mm screw.
      Ask FixBot
    2. HP Envy M6-1205DX RAM Replacement: step 5, image 1 of 1
      • Slide the center panel down to remove it.
      Ask FixBot
    1. HP Envy M6-1205DX RAM Replacement, RAM: step 6, image 1 of 1
      • To release the RAM push out on the two release mechanisms holding it down.
      Ask FixBot
    2. HP Envy M6-1205DX RAM Replacement: step 7, image 1 of 1
      • Lift gently up on the RAM to position it for removal.
      Ask FixBot
    3. HP Envy M6-1205DX RAM Replacement: step 8, image 1 of 1
      • Gently pull the RAM out of its slot.
      Ask FixBot
    4. HP Envy M6-1205DX RAM Replacement: step 9, image 1 of 1
      • Upon removing the first stick of RAM you will find a second RAM stick located beneath it.
      • Release the second RAM stick by pushing the two release mechanisms outward.
      • Pull the RAM stick out.
      Ask FixBot
Ryan Hatton
634 Reputation
5 Guides authored
IUPUI, Team S2-G2, Wilson Fall 2019 Member of IUPUI, Team S2-G2, Wilson Fall 2019
IUPUI-WILSON-F19S2G2
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 57
All Time: 588
