HP Envy M6-1205DX Hinge Replacement
  1. HP Envy M6-1205DX Hinge Replacement, Battery: step 1, image 1 of 1
    • Lay the device face down to begin.
    Ask FixBot
  2. HP Envy M6-1205DX Hinge Replacement: step 2, image 1 of 1
    • Slide the release mechanism to the left to release the battery.
    Ask FixBot
  3. HP Envy M6-1205DX Hinge Replacement: step 3, image 1 of 2 HP Envy M6-1205DX Hinge Replacement: step 3, image 2 of 2
    • Remove the battery.
    Ask FixBot
  4. HP Envy M6-1205DX Hinge Replacement, Touchpad: step 4, image 1 of 1
    • Using a Phillips #1, remove the 8 10.6mm screws.
    • Also using a Phillips #1, remove the 8.6mm screw.
    Ask FixBot
  5. HP Envy M6-1205DX Hinge Replacement: step 5, image 1 of 1
    • Slide the center panel down to remove it.
    Ask FixBot
  6. HP Envy M6-1205DX Hinge Replacement: step 6, image 1 of 1
    • Using a Phillips #1, remove the 3.5mm screw.
    • Our computer did not come with a hard drive so you should have one in the empty hole. We have marked where we believe the screws will be in orange.
    • Using a Phillips #1, remove the four 10.6mm screws.
    Ask FixBot
  7. HP Envy M6-1205DX Hinge Replacement: step 7, image 1 of 1
    • Pull the disk drive out to remove it.
    Ask FixBot
  8. HP Envy M6-1205DX Hinge Replacement: step 8, image 1 of 2 HP Envy M6-1205DX Hinge Replacement: step 8, image 2 of 2
    • Using a Phillips #1, remove the two 2.4mm screws.
    Ask FixBot
  9. HP Envy M6-1205DX Hinge Replacement: step 9, image 1 of 2 HP Envy M6-1205DX Hinge Replacement: step 9, image 2 of 2
    Tool used on this step:
    Buy
    • Flip the black tab up on the clamp that holds the ribbon cable in place.
    • Pull the cable back with your fingers or a pair of tweezers.
    Ask FixBot
  10. HP Envy M6-1205DX Hinge Replacement: step 10, image 1 of 2 HP Envy M6-1205DX Hinge Replacement: step 10, image 2 of 2
    • Flip the computer back over
    • Use the plastic opening tool to pry the keyboard up .
    Ask FixBot
  11. HP Envy M6-1205DX Hinge Replacement: step 11, image 1 of 3 HP Envy M6-1205DX Hinge Replacement: step 11, image 2 of 3 HP Envy M6-1205DX Hinge Replacement: step 11, image 3 of 3
    • Carefully lift the keyboard up.
    • Flip up the black tab holding the large ribbon cable down.
    • Push both sides of the small white tab forward to release the small ribbon cable.
    • Pull both the cables out to remove them.
    • Remove the keyboard.
    Ask FixBot
  12. HP Envy M6-1205DX Hinge Replacement: step 12, image 1 of 3 HP Envy M6-1205DX Hinge Replacement: step 12, image 2 of 3 HP Envy M6-1205DX Hinge Replacement: step 12, image 3 of 3
    • Flip the small white tab up to release the ribbon cable.
    • Pull to remove.
    • Repeat the same steps for the other cable.
    Ask FixBot
  13. HP Envy M6-1205DX Hinge Replacement: step 13, image 1 of 1
    • Using a Phillips #1, remove the four 5.6mm silver screws.
    Ask FixBot
  14. HP Envy M6-1205DX Hinge Replacement: step 14, image 1 of 2 HP Envy M6-1205DX Hinge Replacement: step 14, image 2 of 2
    • Use the plastic opening tool to pry the face plate off the rest of the frame.
    • Once you pry all of the snaps up lift the face plate off.
    Ask FixBot
  15. HP Envy M6-1205DX Hinge Replacement, Hinges: step 15, image 1 of 2 HP Envy M6-1205DX Hinge Replacement, Hinges: step 15, image 2 of 2
    • Pull up on the black tab to unplug the cable that goes into the screen
    • The cable will be stuck onto the motherboard and will need to be pulled off. The adhesive is very weak and the cable will stick back down when you are finished.
    Ask FixBot
  16. HP Envy M6-1205DX Hinge Replacement: step 16, image 1 of 1
    • Using a Phillps #1, remove the two 5.6mm silver screws from the base of the first hinge.
    Ask FixBot
  17. HP Envy M6-1205DX Hinge Replacement: step 17, image 1 of 1
    • Also using a Phillips #1, remove the two 5.6mm silver screws from the base of the second hinge.
    Ask FixBot
  18. HP Envy M6-1205DX Hinge Replacement: step 18, image 1 of 1
    • Using a plastic opening tool, carefully start prying the frame of the screen up
    Ask FixBot
  19. HP Envy M6-1205DX Hinge Replacement: step 19, image 1 of 1
    • When prying the screen frame off be careful around the top edge as your webcam will be there. It is a safe idea to move it out of the way like am I doing now.
    Ask FixBot
  20. HP Envy M6-1205DX Hinge Replacement: step 20, image 1 of 1
    • Remove the three 1.9mm silver screws from the base of the screen frame using the Phillips 00 screwdriver.
    • If you are doing this guide as a prerequisite to replace the screen, stop here and skip ahead to step 23
    Ask FixBot
  21. HP Envy M6-1205DX Hinge Replacement: step 21, image 1 of 2 HP Envy M6-1205DX Hinge Replacement: step 21, image 2 of 2
    • Carefully pry the edge of the frame up to expose the other half of the first hinge.
    • Using a Phillips #1, remove the three 2.8mm silver screws.
    • Pull the hinge out.
    Ask FixBot
  22. HP Envy M6-1205DX Hinge Replacement: step 22, image 1 of 2 HP Envy M6-1205DX Hinge Replacement: step 22, image 2 of 2
    • Care full pry up the other corner of the frame
    Ask FixBot
4 other people completed this guide.
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 40
All Time: 7,426
