Up to 20% off select tools
HP Envy Battery Replacement
Views: 53K
View statistics:
Past 24 Hours:
14
Past 7 Days:
119
Past 30 Days:
442
All Time:
53,199
Comments: 10
1 comment on steps, 9 guide comments.
Go to guide comments
Completed: 21
21 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 45 minutes
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
Has your battery seemingly died far earlier than expected in your HP Envy 15 x360 laptop? This guide will show you how to fix a common cause of a dead battery.
    1. HP Envy Battery Replacement, Battery: step 1, image 1 of 1
      • Plug in your computer to charge and take a look at the light coming from near the charging port.
      • If the light is a steady orange or white, your computer should be charging normally and this guide is no longer necessary.
      • If the light is a blinking white, your computer is not charging properly and you should proceed to the next step.
      Ask FixBot
    2. HP Envy Battery Replacement: step 2, image 1 of 1
      • Flip the laptop over on its back and remove the two depressed stickers in the middle to reveal the two central 6.0 mm Phillips-head screws.
      Ask FixBot
    3. HP Envy Battery Replacement: step 3, image 1 of 1
      • Use a spudger to pry up the two rear feet near the hinge.
      • You don't need to pry up the two feet near the front of the laptop as there are no screws underneath them.
      Ask FixBot
    4. HP Envy Battery Replacement: step 4, image 1 of 3 HP Envy Battery Replacement: step 4, image 2 of 3 HP Envy Battery Replacement: step 4, image 3 of 3
      • Use a Phillips screwdriver to remove the 14 screws securing the back cover.
      Ask FixBot
    5. HP Envy Battery Replacement: step 5, image 1 of 3 HP Envy Battery Replacement: step 5, image 2 of 3 HP Envy Battery Replacement: step 5, image 3 of 3
      • Once all of the screws have come out, flip the laptop over and open the lid so that the keyboard is face up.
      • Pop the keyboard from the sides and carefully lift it off of the parts underneath.
      • DO NOT pull the keyboard away from the rest of the laptop too quickly. There are various cords and wires connecting the keyboard section to the rest of the computer that should remain plugged in.
      Ask FixBot
    6. HP Envy Battery Replacement: step 6, image 1 of 1
      • Carefully lay the keyboard section against the open screen of your laptop without unplugging anything.
      • Check the inside of your laptop to make sure there are no glaringly obvious problems (insects, missing parts, scorched parts).
      Ask FixBot
    7. HP Envy Battery Replacement: step 7, image 1 of 3 HP Envy Battery Replacement: step 7, image 2 of 3 HP Envy Battery Replacement: step 7, image 3 of 3
      • Locate the battery and the three 4.0 mm Phillips-head screws that hold it in place.
      • Unscrew these three screws and use the tab attached to the battery to remove it safely from the laptop.
      • Unplug the cord attaching the battery to the motherboard. This is the only cord that should be unplugged throughout the entire fix.
      Ask FixBot
    8. HP Envy Battery Replacement: step 8, image 1 of 2 HP Envy Battery Replacement: step 8, image 2 of 2
      • Once the battery is safely removed, plug the charging cord into the charging port on the side and plug the other end into the wall.
      • DO NOT turn the computer on or touch any of the internal components during this step.
      • If the light is on after plugging it in, you have just confirmed that something is wrong with the battery, which means you're on the right track!
      • If the light on the side blinks upon plugging it in, the battery is not the problem. If that is the case, put your laptop back together and consult an expert.
      • Unplug the charging cable.
      Ask FixBot
    9. HP Envy Battery Replacement: step 9, image 1 of 3 HP Envy Battery Replacement: step 9, image 2 of 3 HP Envy Battery Replacement: step 9, image 3 of 3
      • Place the battery back where it was previously and find where it was plugged in.
      • Due to general wear and tear, often this will become slightly unplugged, causing the laptop to fail to charge properly.
      • Plug the cable on the battery back into the port on the motherboard and make sure it is secured.
      Ask FixBot
    10. HP Envy Battery Replacement: step 10, image 1 of 1
      • Run the earlier test from Step 7 that you performed on the laptop with the battery inside.
      • If the light comes on and doesn't blink, you have fixed the problem! Congratulations!
      • If the light still blinks, you may have to purchase a new battery for your laptop.
      Ask FixBot
21 other people completed this guide.
Author
with
Connor French
1,493 Reputation
2 Guides authored
Cal Poly, Team 17-2, Green Fall 2015 Member of Cal Poly, Team 17-2, Green Fall 2015
CPSU-GREEN-F15S17G2
4 Members
60 Guides authored
9 Guide Comments
In addition to the screws shown there are two screws under the pads close to the hinges. Pry the pads off and remove the screws under them. Then follow the instructions.
Tom D
Tom - Reply Share
can you tell me the name of the battery ?
عبدالسلام محمد - Reply Share
Worked like a gem. Now my battery is even charging. There must be a loose connection between the battery and mother board. Double thumbs up to you!
ganesh_sarma478 - Reply Share
Agree with Tom - I put the comment under the step where the screws are.
Sean C - Reply Share
This worked like a charm for me. Thank you for posting!! followed directions exactly, so easy to follow. The only trouble I had was getting the keyboard detached. It was really stuck on there, but I eventually got it. Battery is charging as we speak.
julieb6148 - Reply Share
Past 24 Hours: 14
Past 7 Days: 119
Past 30 Days: 442
All Time: 53,199
