HP Envy 700-030qe Solid State Drive Replacement
  1. HP Envy 700-030qe Solid State Drive Replacement, Solid State Drive: step 1, image 1 of 1
    • Before beginning, it is good to wear an anti-static wrist band to prevent electrical components from getting harmed.
    • Attach the anti-static wristband to your wrist, and clip the other end to an exposed piece of metal anywhere on the case.
    Ask FixBot
  2. HP Envy 700-030qe Solid State Drive Replacement: step 2, image 1 of 1
    • Start by opening the device case by unscrewing the 10.5mm hand screw on the back of the computer.
    • If the hand screw is too tight, you may use the Torx T15 screwdriver to remove it.
    Ask FixBot
  3. HP Envy 700-030qe Solid State Drive Replacement: step 3, image 1 of 1
    • Turn the computer onto its side to continue removing the case cover.
    • Slide the cover off by sliding it to the right.
    Ask FixBot
  4. HP Envy 700-030qe Solid State Drive Replacement: step 4, image 1 of 2 HP Envy 700-030qe Solid State Drive Replacement: step 4, image 2 of 2
    • Locate the SSD inside the open case.
    • Unplug the SATA power cable from the hard drive by pulling straight up.
    Ask FixBot
  5. HP Envy 700-030qe Solid State Drive Replacement: step 5, image 1 of 1
    • Finish disconnecting the hard drive by unplugging the black SATA interface cable by pulling up.
    Ask FixBot
  6. HP Envy 700-030qe Solid State Drive Replacement: step 6, image 1 of 1
    • To remove the SSD and its casing, pull out on the side silver tab.
    • At the same time, pull up on the hard drive. It should slide out smoothly without much effort.
    Ask FixBot
  7. HP Envy 700-030qe Solid State Drive Replacement: step 7, image 1 of 1
    • To completly remove the SSD from its casing, unscrew the four 5mm screws on opposite ends of the casing. Use a Torx T15 screw driver to accomplish this.
    • Notice that the screws to remove are the four screws inside the holes rather than the screws that are next to the holes.
    Ask FixBot
  8. HP Envy 700-030qe Solid State Drive Replacement: step 8, image 1 of 1
    • Finally, slide the SSD out of the casing.
    Ask FixBot
5 other people completed this guide.
Chandler Warne
306 Reputation
1 Guide authored
Cal Poly, Team 5-9, Maness Fall 2015 Member of Cal Poly, Team 5-9, Maness Fall 2015
CPSU-MANESS-F15S5G9
4 Members
10 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 39
All Time: 3,099
