HP Envy 700-030qe CPU Fan Replacement
  1. HP Envy 700-030qe CPU Fan Replacement, CPU Fan: step 1, image 1 of 3 HP Envy 700-030qe CPU Fan Replacement, CPU Fan: step 1, image 2 of 3 HP Envy 700-030qe CPU Fan Replacement, CPU Fan: step 1, image 3 of 3
    • Make sure that you are wearing your anti-static wristband. This will prevent damaging any internal parts with any built up static electricity.
    • Unscrew the 10.5mm screw on the left of the desktop using your hand.
    • If it is too tight you may use a torx-head screwdriver or a flat-head screwdriver.
    Ask FixBot
  2. HP Envy 700-030qe CPU Fan Replacement: step 2, image 1 of 2 HP Envy 700-030qe CPU Fan Replacement: step 2, image 2 of 2
    • Next, remove the side panel by sliding it towards the back of the desktop and pulling up, as shown.
    Ask FixBot
  3. HP Envy 700-030qe CPU Fan Replacement: step 3, image 1 of 1
    • Remove the four 120mm Phillips #000 head, 5 mm screws holding the fan.
    Ask FixBot
  4. HP Envy 700-030qe CPU Fan Replacement: step 4, image 1 of 1
    • Carefully pull up and disconnect the fan's power cable.
    Ask FixBot
  5. HP Envy 700-030qe CPU Fan Replacement: step 5, image 1 of 1
    • Remove the fan by pulling up carefully.
    Ask FixBot
2 other people completed this guide.
Jessica Resta
235 Reputation
1 Guide authored
Cal Poly, Team 5-9, Maness Fall 2015 Member of Cal Poly, Team 5-9, Maness Fall 2015
CPSU-MANESS-F15S5G9
4 Members
10 Guides authored
4 Guide Comments
Im looking to replace the fan in mine, what size would I look for, or even what model would be best?
AzyP Zero - Reply Share
Did you ever determine what fan to use ? I need to order one for my system.
Dennis - Reply Share
I bought the Philips #000 Screwdriver from iFixit as listed above. It is not even close to what is needed. That screwdriver is like a jewelers tiny Philips head. It needs a much bigger screwdriver.
Fails to mention the most important part of the entire procedure. That would be to remove the old thermal paste from the top of the CPU with 91-99% isopropyl alcohol and re-apply new thermal paste. Short of doing this almost guarantees failure to maintain proper cooling.
Guy Martin - Reply Share
Past 24 Hours: 3
Past 7 Days: 13
Past 30 Days: 59
All Time: 4,148
