HP Envy 5660 Printhead Replacement
    1. HP Envy 5660 Printhead Replacement, Printhead: step 1, image 1 of 1
      • Open the printer so that the underside of the scanner is showing.
      Ask FixBot
    2. HP Envy 5660 Printhead Replacement: step 2, image 1 of 1
      • Unscrew the black 11.5 mm screw closest to the front right corner using a T10 screw bit.
      Ask FixBot
    3. HP Envy 5660 Printhead Replacement: step 3, image 1 of 1
      • Remove right side of the printer using a plastic opening tool or metal spudger.
      Ask FixBot
    4. HP Envy 5660 Printhead Replacement: step 4, image 1 of 1
      • Remove spring from the side of the print head rail using a metal spudger.
      Ask FixBot
    5. HP Envy 5660 Printhead Replacement: step 5, image 1 of 2 HP Envy 5660 Printhead Replacement: step 5, image 2 of 2
      • Push the metal rail the print head rests on inwards to remove it from its bearings.
      Ask FixBot
    6. HP Envy 5660 Printhead Replacement: step 6, image 1 of 1
      • Remove the belt from the back of the print head using a metal spudger.
      Ask FixBot
    7. HP Envy 5660 Printhead Replacement: step 7, image 1 of 1
      • Remove the print head from the metal rail by sliding it off the rail.
      Ask FixBot
Ryan Steakley
790 Reputation
5 Guides authored
Cal Poly, Team S1-G6, Livingston Winter 2018 Member of Cal Poly, Team S1-G6, Livingston Winter 2018
CPSU-LIVINGSTON-W18S1G6
4 Members
60 Guides authored
1 Guide Comment
I wouldn't recommend this guide to anyone without prior experience as it's non-thorough and missing many steps. Started with a clogged printhead; finished with a torn ribbon cable and a couple other new damages.
Ryan Steakley's Dad - Reply Share
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 49
All Time: 6,870
