HP Envy 5660 LCD Replacement
    1. HP Envy 5660 LCD Replacement, LCD: step 1, image 1 of 1
      • Lift the scanner to open up the printer cartridge access area.
      Ask FixBot
    2. HP Envy 5660 LCD Replacement: step 2, image 1 of 2 HP Envy 5660 LCD Replacement: step 2, image 2 of 2
      • Remove the two 12 mm screws with a T10 bit.
      Ask FixBot
    3. HP Envy 5660 LCD Replacement: step 3, image 1 of 3 HP Envy 5660 LCD Replacement: step 3, image 2 of 3 HP Envy 5660 LCD Replacement: step 3, image 3 of 3
      • Use a metal spudger to pry open the front panel.
      • Work your way all the way around the front panel doing the same.
      • Gently flip the cover over, exposing the motherboard.
      • There will be loud popping sounds when the cover is being separated from the rest of the printer.
      Ask FixBot
    4. HP Envy 5660 LCD Replacement: step 4, image 1 of 2 HP Envy 5660 LCD Replacement: step 4, image 2 of 2
      • Remove the four 4.5 mm screws from the motherboard with a T6 bit.
      • Gently remove the motherboard from the top of the LCD, but make sure the ribbon cables are still attached.
      • Beware damaging the white ribbon cable.
      Ask FixBot
    5. HP Envy 5660 LCD Replacement: step 5, image 1 of 2 HP Envy 5660 LCD Replacement: step 5, image 2 of 2
      • Remove the four 5 mm screws with a T6 bit, allowing you to separate the LCD from the cover,
      Ask FixBot
    6. HP Envy 5660 LCD Replacement: step 6, image 1 of 1
      • Place the metal spudger underneath the LCD and gently lift up to remove the LCD.
      Ask FixBot
Ryan Steakley
790 Reputation
5 Guides authored
Cal Poly, Team S1-G6, Livingston Winter 2018 Member of Cal Poly, Team S1-G6, Livingston Winter 2018
CPSU-LIVINGSTON-W18S1G6
4 Members
60 Guides authored
2 Guide Comments
Great description but there is a part needed - the LCD. Is that part available? How do I get it?
Thanks,
PJE
pateckelberry - Reply Share
Ditto, I'm in the same position, did you ever find the part/LCD replacement screen?
Tessa Robles - Reply Share
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 29
All Time: 1,846
