Up to 20% off select tools
HP Envy 4520 LCD Screen Replacement
Views: 2.6K
View statistics:
Past 24 Hours:
6
Past 7 Days:
21
Past 30 Days:
81
All Time:
2,560
Comments: 5
5 comments on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 7 - 10 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
The replacement of LCD screen will require a T10 and a T6 screwdriver.
    1. HP Envy 4520 LCD Screen  Replacement, LCD Screen: step 1, image 1 of 2 HP Envy 4520 LCD Screen  Replacement, LCD Screen: step 1, image 2 of 2
      • Lift the scanner bed.
      Ask FixBot
    2. HP Envy 4520 LCD Screen  Replacement: step 2, image 1 of 2 HP Envy 4520 LCD Screen  Replacement: step 2, image 2 of 2
      • Remove the T10, 13 mm center screw.
      Ask FixBot
    3. HP Envy 4520 LCD Screen  Replacement: step 3, image 1 of 3 HP Envy 4520 LCD Screen  Replacement: step 3, image 2 of 3 HP Envy 4520 LCD Screen  Replacement: step 3, image 3 of 3
      • Slide the front panel to the right, then lift the front panel upwards.
      Ask FixBot
    4. HP Envy 4520 LCD Screen  Replacement: step 4, image 1 of 3 HP Envy 4520 LCD Screen  Replacement: step 4, image 2 of 3 HP Envy 4520 LCD Screen  Replacement: step 4, image 3 of 3
      • Remove the large flat ribbon cable by pinching the top and bottom of the cable between thumb and index finger and pulling away from the mother board.
      • Remove the small flat ribbon cable by pinching the top and bottom of the cable between thumb and index finger and pulling away from the mother board.
      Ask FixBot
    5. HP Envy 4520 LCD Screen  Replacement: step 5, image 1 of 3 HP Envy 4520 LCD Screen  Replacement: step 5, image 2 of 3 HP Envy 4520 LCD Screen  Replacement: step 5, image 3 of 3
      • Remove the four T6, 7 mm mounting screws.
      • Remove the LCD screen out of the plastic housing.
      Ask FixBot
Author
with
Markell Parks
316 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 21
Past 30 Days: 81
All Time: 2,560
